Question about Maytag 23 cu. ft. Side-by-Side Refrigerator MSD2356
Space between doors on cabnet is very hot to touch ref seems to work ok
Maytag model MSD2356AE sapce were doors seal in center of cabnet very hot to touch
  • 943 Answers
Hi. thanks for the question .the heat between the doors is normal . its hot to keep condensation from running down the doors .but pull fridge away from wall. remove back panel and clean all the coils. very important. thanks the appliance doc
Posted on Sep 30, 2008
  • wissing2writ
    wissing2writ Apr 13, 2013
    We have this too, but the water from the door will be hot then cold then hot too. Is that normal also?
Door seal is very hot
This may be a sign of a failed condenser fan or an overly dirty condenser that could lead to problems. Here is a link to instructions I put together on taking care of this. Let me know if this helps.
Thanks.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
May 05, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
The doors are scorching hot to touch on my Maytag 2454. It's always been warm to touch, but all of a sudden it is too hot to even touch. It is in the center part of both doors, along the door seal area and...
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Apr 22, 2010 | Maytag MSD2454G Side by Side Refrigerator
Typewriter wont type past center point
You probably hae th R. margin set there. Space to that point touch the margin release ke sapce to hefar rght, press te R. mar. key.
DickyO
Jul 01, 2009 | Olympia Startype 3 Typewriter
Maytag mff2557hes icebox not cold, freezer works.
OK, I will take you to the Maytag Service Library, You will need to put your refrigerator through some self diagnostic to locate the problem, click on link below and let me know when you are ready, Thanks, Sea Breeze
http://www.servicematters.com/maytag_library/docs/16025690.pdf
May 22, 2009 | Maytag MFF2557HES Stainless Steel French...
Compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
May 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Maytag side by side doors hot
hi there,
you may have a clogged vent, preventing air circulation. is there are vent on the bottom by the crispers?
Sep 29, 2008 | Maytag Refrigerators
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Feb 13, 2008 | Refrigerators
Refrigerators Logo
878 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
