Question about Whirlpool ET8MTKX Top Freezer Refrigerator
FREEZER ICES UP
BACK WALL OF THE FREEZER ICES UP AND THEN THE FREEZER IS JUST COOL.. COULD IT BE THE TIMER OR THE DEFROST ELEMENT -- IF SO HOW DO I CHECK THEM AND WHERE ARE THEY?? WHAT OTHER PROBLEMS CAN CAUSE THIS AND HOW DO I FIX THEM??/
  • 172 Answers
Hi Jutin Bako,
The heater is located inside the freezer behing the back panel. You will located the heater just underneath the coil. 90 % of the time when you have a frost problem it is the heater. To check it all you need to do is check for continuity through it. If the heater is good you will need to check the defrost timer. To check it simply turn the timer around until you hear a click, this will put the refrigerator into defrost and it should begin to melt the ice. Wait a few minutes and the refrigerator shoud start running again. If it never comes out of defrost then the timer is bad.. The timer will be located in the top section of the freshfood side near the light. You will see a small hole about 3/8th to 1/2 inch. Take a flat blade screwdriver and place it into the hole. You should be able to turn the timer clock wise untill you hear the click. This will put the refrigerator into defrost. . The following are the possible parts you will need.
defrost timer. #482493 price $20.00
heater #2176300 price $30.00
I hope this will fixYa. and pleast rate me.
Mike
Posted on Sep 30, 2008
My Hotpoint refrigerator is not staying cool and the freezer is not keeping things frozen.
Is there ice accumulation on the back wall of freezer? If so the auto defrost mechanism consisting of defrost timer, heat element, defrost timer is defective.
Is your thermostat working properly and not turning things off prematurely?
Freezer fan spinning?
Compressor running?
Check out the above.
Sep 09, 2015 | Hotpoint Refrigerators
Freezer ices up
Sounds like you have a defrost problem. The parts for your defrost cycle are.
1. Bimetal part# 4387503
2. Heater part# 2315531
3. Defrost timer Part# 482493
The heater and the bimetal is located in the freezer dept. behind the back wall. The defrost timer is located behind the cold control plate in the refrigerator department.
http://www.on-timeappliance.com/refrigeratorrepair.html
Mar 28, 2012 | Whirlpool GR9SHMXLB / GR9SHMXLL Top...
Every 3 weeks the freezer ices up on back wall and the fan isn't able to circulate the cool air. i defrost it and then the unit works perfectly for about three weeks and it happens again.
You have a problem with the automatic defrost system. It could be the defrost timer or defrost heater or termination theromstat. You woulld have to check them to see what part is bad. Hope this helped. I don't know if you have the knowledge or the tools to repair it yourself or if you need to call repair tech.
May 25, 2011 | Kenmore Refrigerators
Freezer ices over too fast and refrigerator doesn't cool.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2010 | Magic Chef CTF2125 Top Freezer...
My Ammana Freezer is not defrosting. I need to figure out if it is the Defrost Thermostat Defrost Timer or the heating element. What should I do first?
in most cases its the defrost element as the other units last much longer unless the fan has become jammed this happens when people toss meat hard against the back wall if you know how to do polaity test using a multimeter do test on defrost element its not a thermistate as new age frezzers dont use them they use timers and plastic channels to curculate cool air
good luck need more addvice email me
Jun 25, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
Model number 106.64232400. the fridge is warm, large amount of ice in the freezer. moved items to help with the venting. how should i get rid of all of the ice build up???
If the ice is on the back wall, melt it with a hairdryer, then remove the back wall and drfrost the evaporator coils. You will now have a few days to fix your defrost system before it ices up again.
check defrost timer, defrost heater, defrost thermostat.http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 07, 2009 | Refrigerators
Freezer is frozen and Refridgerator not cooling
It sounds like you have aproblem with the defrost cycle. Three parts make up defrost system in most refrigerators. The heating element, bimetal and defrost timer, these components need to be checked to determin which is bad. The heating element and bi metal are on the coil behind the freezer back wall, if you have someone who can use a volt ohm meter, with the food removed and refrigerator unplugged ck for resistance on the element if you get a measurment its good, the bimetal will give you a resistance measurment as long as its covered in ice. if these two check ok you may have a bad defrost timer. Id check the bimetal first, hope this helps.
Mar 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer keeps iceing up on older kenmore bottom freezer top fridg
Hi,It is one of three things,
1:Defrost timer
2:Defrost element
3:Defrost thermostat
Please rate this solution
Jan 18, 2009 | Refrigerators
Refrigerator does not cool
check the defrost themostat (replace) make sure the fan is working and that the defrost heater works as well.see if the timer will run and turn of the heater.
Jul 09, 2008 | Refrigerators
Whirlpool ET8MTKX Top Freezer Refrigerator Logo
148 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
