Question about Microsoft Xbox 360 Console
Mtu settings on xbox 360
Hey, can u help me? my xbox was perfect but now whenever i test the xbox live connection the mtu setting fails. Can u please help me? my router is set fine, its just my xbox.
If you have lynksis for a router you can go to 192.168.1.1 on your address bar and for the password and username they both are admin after that go to MTU and change the size. for XBOX LIVE you need 1365 or greater. If it is already greater than 1365 you might want to switch it to manual and put it directly to 1365. Then save settings and you are done
Posted on Nov 14, 2008
    Problem Solver:
  • 7 Answers
Ur xbox will be fine naw it was turned off by xbox for 24h on the 29 th
Posted on Oct 01, 2008
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
Hey i have a thomson TG782T and i am trying to connect an xbox 360 elite to xbox live through an ethernet cable and i am having the mtu error come up. i already have an xbox 360 slim connected which works...
Maximum transmission unit is 1500, but for the Xbox 360 it "must" be set within the range 1364 - 1492
Since there's no MTU settings for the TG782T. your only choice is to replace it with routers like Linksys, Belkin, Netgear.
Jan 05, 2011 | Microsoft Xbox 360 Console
I can't connect my Xbox 360 into LIVE because the
This option is available via the web interface under the WAN Settings screen.
Nov 29, 2009 | 3Com OfficeConnect Wireless Router
How do I change my MTU settings?
Today would be a bad time to test for a connection issue with XBox Live. It is down today for maintenance, if it worked before today, I would just wait until tomorrow and try again.
http://www.product-reviews.net/2009/06/16/xbox-live-down-on-june-16-maintenance-also-for-zune/
Jun 16, 2009 | Belkin (F5D5231-4) Router
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Connection problems
MTU stands for "Maximum Transmission Connection". Some routers and/or network gateways are incompatible with Xbox LIVE, while others may be compatible but merely need to have a setting changed. If you compare your router to the list of routers at the following web address, you can confirm whether or not your hardware has been confirmed as compatible with Xbox LIVE by Microsoft:
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
Whether or not your hardware is listed as compatible, it would still be a good idea to check your instruction manual for the hardware you are using and see how (if possible) to change the MTU settings. Microsoft suggests that the MTU setting should be 1364. Using untested hardware or hardware not listed as compatible may still work, however, future updates to LIVE may suddenly make your hardware incompatible, as updates to LIVE and the Xbox console are made to work with the specifications of tested and listed compatible routers and gateways.
Aug 13, 2008 | Microsoft Xbox 360 Console
Xbox live cant connect mtu failed
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
Xbox 360 live states MTU failed
for some reason i cant connect to live, it says that my mtu has failed. any surgesstions how i solve this??
May 18, 2008 | Microsoft Xbox 360 Console
Mtu
If you have your Xbox connected through a router, most routers, on their control panel (192.168.1.100 for example) give you the option of setting an MTU, or leaving it to default. This option is normally found on the setup page of your routers control panel.
MTU stands for maximum transmission unit, basically a speed thing.
If you can set it, change it to something above 1500 depending on how fast your internet connection is, but I am fairly certain that 1500 is the minimum that you would want to have set for xbox live.
Another way to do it is, if your router has this option, set the MTU to Automatic. That way your router (should) be able to do all of that dynamically as the need arises.
I hope this helps to solve your problem, good luck!
May 16, 2008 | Microsoft Xbox 360 Console
MTU fail actiontec gt704wg
I opened my xbox 360 and i did not see a switch any where. don't do it its a lie.
Jan 06, 2008 | Actiontec (GT704WG) Router
Microsoft Xbox 360 Console Logo
264 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
