Question about Ardisam Garden
Older model earthquake rear tine tiller won't start
I have an older model earthquake rear tine tiller. It has been sitting for about three months. I tried startign it today, but had no luck. I can't tell if it's getting enough gas. I put new gas in it and checked the spark plug. I thought that I may have to clean the carb. Any help is appreciated.
  • 163 Answers
Try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Posted on Nov 30, 2008
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
Why is the belt wearing out so quick, i have used my brand new earthquake rear tine tiller less than ten hours and have gone thru three belts.
-The pulley, idler are not line up and may be too sharp edges. or may be some other part is touching the belt when is running.
Good luck
mai
Jun 08, 2014 | Ardisam Inc Earthquake Mini Cultivator
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
Earthquake rototiller won't disengage
the tensioner is to tight and belt stays engaged loosen the tension below the handle
Apr 04, 2014 | Earthquake 6015V Rear Tine Rototiller
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
Need a user manual for Earthquake 3365PS tiller
I need a service manual for the earthquake 9800 auger with the 3.8 hp tecumseh.
May 12, 2010 | Ardisam 5.5 Hp Rear Tine Rototiller
Rototiller wonts change gears
Try rocking the wheel as you try to shift.
Apr 30, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
I need a forwward cable for an earthquake reartine rototiller #5020dm how to order. thanks
I googled Earthquake 5020DM tiller and show a site that has a technical manual. It has the diagrams and parts numbers. It looks like the forward and reverse cable are the same. You may have to call ARDISAM direct to get the cable.
Oct 02, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Garden Logo
581 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Shehu Pro
Shehu Pro
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
