Hi there, have a Samsung DVDV6800 purchased in July that wont play all region discs. Can you tell me how to put in the codes for multi zones?
  • Anonymous Sep 30, 2008
    I have the same problem. Have you got a fix yet?? Cheers.
    Tone
1. Power on your player with no disc in the tray. Wait for message "No Disc" in the top left hand corner of your screen.
2. Press and hold the Repeat button on your remote control for approximately 5 seconds.
3. Enter the code below. (Note that you must know what Region your player is currently set to in order to know which code is appropriate.)
for Region 1 use 2, 9, 3, 3 and 4
for Region 2 use 3, 8, 7, 6 and 7
for Region 3 use 5, 6, 7, 3 and 2
for Region 4 use 7, 6, 8, 8 and 4
for Region 5 use 5, 3, 8, 1 and 4
for Region 6 use 2, 4, 4, 6 and 2
4. The message "No Disc" will now be replaced with the default region number of your player. For example, Australian and N.Z players will display a small "4".
5. Press "9" for multi-region.
6. Open tray and insert your title.
7. Close tray.
The player will continue to hold the changes you have made. If this does work for you the first time, keep repeating steps 2&3 until the players default region number appears. The amount of time holding the repeat button does seem critical.
Posted on Apr 20, 2009
Make sure the player is switched on, and is at the Samsung logo
screen. Also check the tray is shut and that there's no disc in the
player.
Now press the REPEAT button on the remote, followed by a five digit
code. This code is different depending on what region your player is
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
If you've done this correctly (and your player is compatible with the
hack), you should see a number at the top left corner of the screen
corresponding to the current region.
Now, pressing any number from 1 to 6 will change to the corresponding
region. Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD
POWER) on the remote to close it and put the player into Standby mode.
The next time you turn your player on, the new region will be set.
Don't forget that if you want to hack it again, you'll need to use a
different code, as listed above. If it's currently set to region 9,
use the code for the last *proper* region you set it to.
Posted on Dec 28, 2008
  • 68 Answers
Apparently they are locked to region 4 and I have bought region 1 DVDs so they won't play
In most models the unit cannot converted to multi-regions.So it will play only in the specified region in which it is applicable to.But in some unit models there is a procedure to turn the unit to multi region so it can play all region dvd.On all models the procedure to convert the unit to multi region is different.As you have not mentioned the exact model number of your unit.t will not be easy to give exact details.If in case there is a procedure to convert your unit to multi region.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Sep 14, 2010 | LG Audio Players & Recorders
We have a Samsung Digital Home Cinema System that will only play DVDsfrom Zone 4 and we have several DVDs from Zone 2. Can you help? MJ
Most DVD played do NOT allow you to change the region, but look up the model number and "change region" and if it can be done it will come up, But frankly I don't think it will, to play muli region discs you have to get a multi region player.
Sep 08, 2009 | Televison & Video
Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Apr 13, 2009 | Yamaha DVD-S661 HDMI DVD Player
How do i get multi zone codes on my dvd player?
1. Ensure disc tray is empty.
2. Press "Repeat" on the R/C then enter 5,7,5,3,8 or the region key for your region.
3. The numbers "02" appear in the top left of the screen.
4. Quickly press the number "0" button on the R/C, for "multi region".
6. Wait 20 seconds, then power off, then on again.
Feb 02, 2009 | Sharp 21" Multi System Stereo TV
Region code
need to know how to play multi zone dvd on my panasonic DMR-EH57.
Jul 11, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Multi Zone code Samsung 5600 DVD VCR Combo
Try this site:
http://www.videohelp.com/dvdhacks/samsung-dvd-v5600/7031#26074
Particularly the entries from:
Region code hack posted by Anthony Green, September 10 2006:
And
Region code hack posted by ZoidsGodzilla, November 22 2006:
Good luck
Jan 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
Sony DVP-NS67P DVD player problem
Hi I also have a NS67P and I'm looking for the unlock code so it can play multi -region
PM: lobo90210ca@gmail.com
Dec 24, 2007 | Sony DVP-NS315 DVD Player
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
750 people viewed this question
Top Televison & Video Experts
