My computer un-expectantly failed on me while I was coding up my game engine. I am currently running: Windows XP SP2 (2)256mb RAM sticks (STOCK) Everything else is entirely stock.. I went out and bought two (2) new 1gb RAM sticks from staples. They are DDR2 Sticks and are PC2- I tried installing them to see if that would fix my problem and still no luck at all and I'm getting very frustrated. Can someone please help me? Thanks in advance, David
SOURCE: computer beeps six times after installing new
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
SOURCE: I am trying to install
I belive the problem is caused due to non compatible memory being installed . According the Dell documentation the memory specification is as under
333- and 400-MHz DDR SDRAM
1Gb Non-ECC on each slot.
Just check the speed of the memory you are trying to connect.
Dell Documentation
Thanks for using Fixya
Proton
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having. A solid green light means the computer is operating normally. A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard. A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced. A blinking green light means the computer is in standby mode. Hope this helps!
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Then join us in our free computer tech support forums and we'll try and help you solve your PC problem. Sometimes, however, a service call to Dell will be required. If your system is still under warranty, you should always just call them first, as tampering with your computer may void your warranty.
Suggested Resolution
Solid green
Power is on, and the computer is
operating normally. On the desktop computer, a solid green light
indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
