Question about GE PSC23MGM Side by Side Refrigerator
Water dispenser slowing to nothing.
PSC23MGSA side by side, cabinet depth. 2-3 years old. filter is current. water dispenser slowing to nothing. Ice maker seems fine. thanks.
  • 172 Answers
Hi montyva,
It sounds like either your water supply to the refrigerator is becoming slower or your inlet valve is defective. You can take the water lined loose behind the refrigerator and run it into a bucket or bowl to check the flow rate. If the water pressure is good replace your intet vavle and the problem will be solved. The inlet valve is the small piece your water line hooks to. It has two plugs on it and a couple water lines. This is an easy repair assuming you can pull out the refrigerator. The part numer for the inlet valve is WR57X10032 the price is $48.68 and available for shipping.
One other possible problem could be the water cooling tank behind the crisper drawers is freezing and water is being blocked. You can take out the drawers and defrost the tank with a hair dryer just to make sure that this is not the problem. If it is frozen, turn your temp control down for the freshfood side of the refrigerator. I hope this will FixYa. Let me know if you have anymore problems. Or if you need me to ship you a part. We are GE factory authorized service center.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Posted on Sep 30, 2008
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have a side by side Whirlpool fridge and the ice maker is not working. If I have it turned on (lever down) and door is closed and water leaks out the front of the ice dispenser and it doesn't seem to...
How old is the fridge? Mine lieterally caught on fire at the start device last weekend. My fridge was manufactured in July 2001. Be careful, The fridge I have is model# ED5FHGXKQ00. I am currently requesting a recall be made by Whirlpool on this appliance.
Other than that it could just be that the ice maker line has frozen or the "arm" in the ice chest is stuck and can't raise itself to pump water directly into the ice trays. Either way be very careful. I hope this was helpful.
Jun 10, 2010 | Refrigerators
4 year old jenn-air refrigerator not making ice
first please check you water delivery chanel behiend icemaker, it may freeze up... second you water valve on bottom part on the back is duel( one valve for water dispencer and another one for ice maker) you have to check if it is a power going to that icemaker valve, unplug icemaker inside freezer and plug back now check for power but you have acting fast, ask somebody for help... and third it could be icemaker it self... good luck for additional questions please totalcarefl@yahoo.com
Sep 09, 2009 | Jenn-Air JCD2295HES Side by Side...
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Water drip at doorfront water dispenser
Hi!!! Yes you can fix it by installing an antisyphon device on your water line leading to the water dispenser..remember i've done this for many years repairing frigs and they all do this they all leak water out alittle bit..Good luck..
Jan 03, 2009 | Refrigerators
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Jan 04, 2008 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
GE PSC23MGM Side by Side Refrigerator Logo
134 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
