Question about Homelite 'Yard Broom' Leaf Blower
Homelite leaf blower bogs down.
I have the homelite model #UT08107. It starts fine but after a few minutes of running it bogs down when i give it gas. Solution?
  • Anonymous Nov 07, 2008
    Had the same problem - did all these suggestions - still the blower would not keep running.
    Scholar:
  • 62 Answers
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 08, 2008
Homelite blower pull cord frozen how do i troubleshoot it
go buy a new blower, you ran the wrong fuell/oil mixture and seized the motor.
May 12, 2014 | Homelite Garden
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
Wheres the air filter located on the homelite ut08107?
It would likely be on the right hand rear corner of the unit while you hold it in an operational position. Look for a choke lever/ knob. The air filter cover is in direct contact with that. Remove the cover ( likely a push clip, possibly a screw or two) and the air filter will be exposed.
Nov 26, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite ut08107 will not fire. no spark at plug.
It may be the coil if there is not any spark. Or a wire could off at the coil. One more thing it could be is the spark plug wire may have came loose from the coil. These a few thing to check.
May 04, 2009 | Garden
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Homelite 'Yard Broom' Leaf Blower Logo
1,668 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
