Question about Haier Refrigerators
Compressor on Haier hmse03waww mini-frige shuts off after 10-20 minutes and is hot to the touch.
  • mcx500 Sep 30, 2008
    I have a feeling that this mini-frige will wind up on the curb, but I am going to do some more tests with the theremostat, etc. before I chunk it. Thank you for your tip. mcx500
  • 172 Answers
If the temperature in the refrigerator is correct then this is proper function for the compressor. It should run until the desired temperature is reached then shut off. The compressor also gets really warm. If the compressor is shutting off prior to the correct temperarure being reached then you may have a compressor problem. If the compressor is bad and our of warranty, it is time for a new refrigerator. If it is still under a warranty, call for factory service. Good luck, and I hope this helps.
Mike
Posted on Sep 30, 2008
My mini fridge stopped working while I was at work
RF-6850-16 Start Relay
Is the compressor again getting hot once you turn the temperature down? Will the refrigerator cool if you turn the temperature to as cold as it can get? Reason I ask is I am trying to decide if it is the thermostat or a defective staryt relay. Even at the cost of parts I would be careful and sure of what you are going to do here. Haier is not well know for quality products or customer support and there are other brands names out there that will support customers much better than Haier. Not trying to say bad things about your refrigerator I just hate to see when people invest into something and then get left holding something that Haier will not help with and does to all of their customer. Thanks Sea Breeze
I have lost valuable customers because of Haiers lack of customer support.
May 29, 2013 | Haier HMSE03WAWW (33 cu ft) Compact...
Haier Mini spilt HSU18VC7 compressor runs for 5 minutes then stop 3 minutes then run another 5 minutes and so on.
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
Aug 03, 2011 | Haier Heating & Cooling
I have a Haier HMSE03WAWW Compact Refrigerator and it was running fine for about a year. All of a sudden it stopped running. I unplugged it for a day and plugged it back in and it started running. Got a...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 05, 2010 | Haier HMSE03WAWW (33 cu ft) Compact...
Frige gets hot and makes clicking noises.
Sounds like the compressor is not working very well the clicking is the compressor starter trying to start the compressor. May be low on freon or bad compressor. You can probaly buy one cheaper than fixing this one
Dec 26, 2017 | Haier Refrigerators
New fridge
Hi!!! sorry to inform you , but you have a seal system problem.Them haier frigs have problems with the seal system..You i\either have a restriction or a leak in the evaporator..
Jan 14, 2009 | Refrigerators
Refrigerators Logo
230 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
