DASH LIGHTS WERE NOT LIT AND HEADLIGHTS WERE DIM. mADE A CLICK CLICK CLICK NOISE WHEN TURNED THE KEY.
If the lights are dim it is a battery problem. It might be a just dirty terminal or the connection on the starter is not good. Check the voltage of the battery with the lights on, should be 12 volts. If it drops when you try to start then it is faulty. The voltage when running should be 14 volts or more.
