Question about Video Game Consoles & Games
My PS3 works in my HDTV but not my Analog tv through the AV Jacks. The plugs in the TV work, I checked them with my Wii and it displayed, but my PS3 will not display. The system is less than a year old and has never been mishandled, it worked in the TV in question as recently as last month and the screen blinks for a moment when it is turned on, but aside from that it is not transmitting audio or video. I thought it was the cable, so I replaced it, but it is not working with the brand new cable either. Can you help or is this something that will require factory repair?
    Problem Solver:
  • 12 Answers
You need to change your video output settings back to component you do so under display settings
Posted on Sep 30, 2008
The av2 input doesnt work
Look for any loose contacts in RC jacks/sockets/Cable. Connect another input on that input of the TV and check. Connect your ps3 to some other TV and check.
Aug 05, 2012 | LG 32LG30 32 in. LCD HDTV
Why will my ps3 not workwhen conected via multi-av cable to the RCA jacks?it does work conected to a hd tv via hdmi
When you use an HDMI cable with your PS3, the system is outputting the signal in a digital format. You need to tell it to switch back to displaying in an analog format to use the RCA jacks, otherwise it won't work. To do this, turn off your PS3. Then, once it's off, press and hold down the power button on the system. After a few seconds, it will beep and reset the output signal back to analog. Just make sure only your RCA cables are plugged in when you do this. Hope this helps!
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
I just bought a Samsung UN22D5000 and I was trying to plug my Nintendo Wii into the tv. I was the Wii's three AV jacks plugged into the correct jacks from the tv and the tv on the only AV source but...
the hdtv you bought is not the right kind for avs and component cables.
yes, i know its a pice of **** now that i explained it. if you still can return
the tv get a different one like a panasonic or a sony anykind exept samsugcuz they r *******
Jul 25, 2011 | Samsung 22 UN22D5000 22 LCD TV
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
Setting up my wii with my trutech tv
The Wii comes with standard AV jacks. Look for the female plug ends on your television that match the colors of the Wii's AV jacks, red, yellow, and white. Plug them in. Turn on TV and Wii. Use the input function of the TV to select the AV input (usually says "game", "video", or "input"). Play Wii.
Dec 16, 2009 | Televison & Video
Nintendo Wii AV Cables not work
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Jul 27, 2009 | Nintendo Wii Console
No TV Connectivity
because it is time to get a new wii
Apr 24, 2009 | Nintendo Wii Console
AV Jacks....
Hi! Try connecting the wires to the same colour jacks and also chekc for AV button on the remote which is sue to switch the TV between AV 1 or AV 2 mode.
Thanks
Rylee
Jan 12, 2009 | Recoton Advent Advent TS2066A TV
HI i have a 42" Hitachi HDTV 1080p (LCD)
Most newer Digital TV's don't display Analog signal very well. Often worse then an Analog TV. This is normal to a degree. If your Wii has component  cables, try using that. As for cable, you might get a better signal with Digital Cable.
Apr 23, 2008 | Hitachi 46F510 46" Projection HDTV
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
107 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
