Question about Whirlpool Duet GHW9150P Front Load Washer
Leaking Duet Washer
Water is leaking at the right rear of our 13-month old Whirlpool washer. The leaking continues after I stop the washer with water in the tub. It isn't leaking out the door and it drained without any problem when I hit the stop button a second time. I'm assuming there is an internal leak and will need to call a repair service. Seems like leaks are not uncommon with these washers based on what I see on the internet
  • waldonia Oct 24, 2008
    Thanks for the advice. Turned out to be a freak failure where the belt was installed incorrectly at the factory. The belt was riding on the pulley flange and partially separated. The broken part began swinging and hitting the vent tube. Eventually it wore a hole in the tube. Since the tube has water in with the washer is running, it leaked. Unfortunately, this item doesn't fail, so the part is back-ordered from Whirlpool. On the good side, Whirlpool is paying for it even though we're a month out of warranty - no arguments from customer service.
  • cwalper Nov 19, 2008
    Mine is doing the same thing. It is just the right lower side of the machine. How do I fix???
    Sergeant:
  • 409 Answers
looks like you may have a pinched hose or the fitting is overtightened or not tightened enough. turn off the water supply and check the water inlet hose. you can usually tell if the fittings are stripped or not tight enough.
Posted on Sep 30, 2008
  • Carmen Mikulic Oct 25, 2008
    phew...im glad that it turned out to be quite simple, even if the part is on b/o. thank you for giving me the opportunity to help you and good luck.
Wfw9150ww00
Make sure your washing machine is on level ground, if the machine is off balance it will stop.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Water continues to trickle into machine when not in use
you have sediment in the water valve on the back of the machine,the valve isn't closing all the way and water is leaking into the washer
Nov 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer leaks water all the time
If it is leaking all the time while running it could be the drain pump. A coin had made its way into mine and cracked the housing. Itis located towards the right rear of the machine on the bottom, while standing in front of the machine.
Mar 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I love my Whirlpool Duet Front Load Washer, but lately, I discovered what I initially thought was incomplete washing/rinse cyles leaving water in the tub, and when I opened the door...water coming out. I...
The problem is commonly caused by either a pressure switch malfunction, or a water inlet valve leaking by. The way you can tell is to leave the water turned on and unplug the washer. If the water continues to flow, the problem is the water inlet valve. If the water stops, the pressure switch.
To access either component, you need to remove the top panel of the washer. Locate the three screws that hold the top panel in place and remove. With the screws removed, the panel will slide back, then lift off. The water inlet valve will be loacted in the left rear of the washer (as viewed from the front). The pressure switch will be in the rear on the right.
To replace the water inlet valve, follow these steps:
1. UNPLUG the washer.
2. Turn off the water source and disconnect the fill hoses from the back of the washer.
3. With the top panel removed, disconnect the dispenser hose(s) and electrical connections to the valve.
4. Remove any mounting screws holding the valve in place and reinstall with a replacement valve.
The pressure switch is even easier. One connector plug and an air hose is the only thing attached to the switch. The switch is usually snapped in place along the interior cabinet wall with no screws holding it in place.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare. The first three sites on the list also include helpful exploded view diagrams of your washer to help with locating parts and assembly.
I hope I've given you enough ideas to work with in narrowing down the cause of your symptoms. This is generally a very simple repair, that isn't very expensive. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Jan 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Duet Washer fills up 1/4 of the tub on its own.
Sounds like a defective fill valve leaking water in although the machine is off.
First turn off your water and remove the hoses. Clean the screens in the hoses and the fill valve.
If that does not correct the problem replace the fill valve.
Feb 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
337 people viewed this question
Dan Webster
Dan Webster
Sal De
