Question about Whirlpool RF367 Electric Kitchen Range
Whirlpool sotve I have an old whirlpool stove with the double oven. The lights come on and the oven takes a long time to heat the burners dont come on period.
  • marywell Oct 01, 2008
    Thank you very much for the advice. When I took the plug apart I had noticed that I had wired it backwards! OOPS!
  • 172 Answers
Hi marywell,
Alot of times this is a sign that the voltage to the range is only half of what it should be. You may have a breaker kicked, or a bad fuse in your fuse box. When the range is only getting 110 volts instead of 220 volts, the oven will slowly heat but nothing else will work. check your breakers and I bet you will have the problem solved. Have a nice night and I hope this will FixYa. Please don't forget to rate me.
Mike
Posted on Sep 30, 2008
Burners work, no display, no oven light, can't turn on oven, buttons don't function
Check your circuit breakers, they should be double breakers. Probably 30 to 50 AMP. Sometimes one side of a double breaker will trip or fail. This will give the appliance 120 volts instead of 220. The "leg" of the 220 volt circuit that is out might control the stove's display, and the oven would not work on 120 volts. If the burners aren't as hot as they should be, or are slow in heating up it would also indicate a faulty breaker If it's not the breakers it's likely a problem in the stove circuitry.
Dec 09, 2014 | Kitchen Ranges
Heating elements on whirlpool electric range do not work
They may just be loose,try push the heating element in to socket,Or remove and check ends,may need cleaning to get good connection.
Dec 25, 2012 | Whirlpool Kitchen Ranges
Whirlpool electric stove oven burners won't heat cooktop works
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 21, 2010 | Whirlpool Kitchen Ranges
I have an old double oven white -westinghouse stove and while i was at work the fuse blew in the basment. well i have reset it but now everything works but my stove. well my oven light will not come on...
Hi, sounds like your oven is a 240 volt electric.  One of your fuses is still blown. 240 volts requires 2 hot legs and obviously you have only one. When you turn on a burner, it completes the circuit to your light. Bottom line, you only have 120 volts to your oven, check the breakers or fuses. Good luck!
Jan 29, 2010 | Kitchen Ranges
My left back burner heats up when the oven is on. i am concerned that this is dangerous and dont know what is wrong. the stove is only 4 years old.
turn on the oven light look down that burner you wil see the inside of the oven it is the oven vent not to worry thumbs up
Aug 12, 2009 | Kitchen Ranges
Whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Whirlpool gas stove
Replace the regulator on the gas line.
Jan 01, 2009 | Whirlpool SF325 Gas Kitchen Range
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RF367 Electric Kitchen Range Logo
99 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
