Question about E-Machines eMachines Desktop PC
Printer new desktop, old printer. Software loaded, says ready, but does not print
  • Massimo Ardito
    Massimo Ardito May 11, 2010
    What type of operative system are you using (Windows XP, Vista, ...)? What type of printer do you have?
My operative system is using a Vista, and my printer is a Lexmark x4270.
Posted on Sep 30, 2008
I am trying to hook a Brother HL-2140 laser printer to a dell computer. I am unable to print since I've recently hook up the new computer. I hooked everything up like how it was on the old...
Re boot the computer with ,( wired or wireless printer?), the printer cable in the USB port in the laptop/desktop, the windows version you have will ID the device and try to load a driver, or Go to printer in the start menu and ADD a PRINTER the software will search for the attached printer. OR use the software that came with the printer, load into the Dell and follow the instructions.
Nov 10, 2012 | Brother HL 2140 Laser Printer
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
Installed a new hp printer. Now evrything runs slowly including the internet
go to START, RUN and type "MSCONFIG" Then after the windows pops up at the top there are tabs. Click on the STARTUP tab, Find your printer software in the startup tab and uncheck it and click apply. This will stop your printer software from starting up every single time you computer boots up, This will not stop you from being able to print only from the software from running from the startup. Some printer software may have to be re-opened when your ready to print but not with most.
Nov 11, 2009 | HP Compaq Presario SR5210NX Desktop PC...
I can;'t print after a power cut.
try this:
1. unistall you printer software and driver
2. change USB location
3. install your printer software and driver
Jul 08, 2009 | Lexmark Office Equipment & Supplies
Can't print from my local printer with Remote Desktop
Try the following :
1. Go to Printers and Faxes
Right click on the printer u are using. Select Share this printer.
2. Set up a home or small office network with Internet connection connected, Printers on on both computers and identify both of them saperately.
For this you need to connect both computers with a cross cable.
3. after the home or small office setup is complete add a new printer from your Printer and Faxes menu. Search your printer automatically and choose it from the llist system provides and select the printer as default if needed.
4. Try taking a 'Test Printout' from the Concerned printer's properties page.
5. if this works, you have successfully installed the printer and are ready to take prints.
Mar 29, 2009 | Sharp AL-1642CS Copier
Printer not printing
Uninstall everything. Reboot. Unplug the printer. Install the software. Reboot. When everyting is up. Plug in the printer. Have the driver disc ready, install the printer. Reboot, go to settings, printers and see if the printer is listed. If it is, make it the default printer.Good luck
Dec 20, 2008 | Computers & Internet
Have changed computers , my printer Lexmark P6350 will not print (running Vista previusly XP)
First thing to do is to uninstall the old driver and software and download and install the latest Vista driver/software for you printer, click here for the printer driver. Make sure that the printer status say's ready and no error messages that you will encounter during the fresh installation.
Nov 04, 2008 | Computers & Internet
I purchased a new lexmark 4 in 1 printer. I am running Wiondows Vista. My old printer (Lexmark) would not load properly so i had to purchase a new one. This one loaded the software and the drivers ok. The...
no go to control panel u see printer and faxes
right clik your printer and chose properties
then go to advanced
and enable button spool print doc...
also clik on start printing immedaitely.
check the button print spoled documents first
also enable advanced featurs.
Sep 29, 2008 | Computers & Internet
Old hp printer won't print anything with new hp desktop computer
Your PC has VISTA loaded (according to the HP web specs)
This printer has no specific driver for VISTA but basic functionality is supported by VISTA without the need to load a seperate driver.
refer HERE
The printer connects via a USB cable to the PC and should be detected automatically by VISTA whe the printer is turned on.
The original CD would have drivers for an earlier vesrion of windows (98 or XP) so you should uninstall any programs that were installed offthe disk.
Post back results or further questions for more assistance
Jul 16, 2008 | HP DeskJet 656c InkJet Printer
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
