SOURCE: MSI 848P Neo-V Motherboard
hi, you will find the drivers you require here.
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=189
All The Best
John
SOURCE: MSI 848P Neo-V Motherboard free download
Yeah suisboy, that's the same link I posted in the earlier post by this guy. He's just an idiot that can't get past the buy now button for the motherboard.
SOURCE: how i can know that motherboards have built in video
none of the cards u enumerated have on board video (don't know about the last one
k9a6m2 f-h )
go on the producers site, at the motherboard u want and look for the back panel I/O ports :
example :
Back Panel I/O Ports
- 1 x PS/2 keyboard
- 1 x PS/2 mouse
- 1 x 3 in 1 audio jack
- 4 x USB 2.0 ports
- 1 x Serial port
- 1 x Parallel port
- 1 x RJ45 LAN jack
- 1 x Graphics Card port (this is what u want)
SOURCE: MSI - 845GLMS (MS-6754) powers off
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=522
Link to board.
Manual: http://global.msi.com.tw/index.php?func=downloadfile&dno=3640&type=manual
This error message may occur if the primary disk group identity of the hard disk does not match the primary disk group identity that is stored in the registry. There wasn't anything wrong with your memory or PSU. (not the cause for blue screen).
If there is data on the primary drive than slave it into another system & copy the data to another drive or CD. The most common data to copy. My Documents, Favorits, Desktop. Users name(jeff), open Application Data, copy Identities. open Mocrosoft, copy Address Book.
What is needed is a fresh install of windows. You can either boot to windows through the cdrom & quick format before install or use the hard drive's utility disk software or CD/iso bootable's to redo the drive. I understand this is a replacement board & one would think that re-connecting everything the system should just boot but from time to time widows gets trashed in the prosses. Though the quick formatt is faster I prefer to use the Mfg's bootable ISO to make a bootable CD. Here you can also check the drive & MBR & pick size & even FAT type.
The choice's are up to you. Just make sure the bios is seeing the drive correctly.
SOURCE: msi 848p neo v , BOOT help
Pull your cmos cell for 15 minutes from motherbord.
Refix your RAM .
Reconnect power code and ide or sata cable to harddisk again.
When you power up the computer pressF2 or "del "key to enter in bios .
Then check your harddisk is detected or not.
I think it may Helpful to you
There is a rate option "Was this helpful?" Yes or No.
If you are helped you can rate, that is your choice.
