Question about GE Profile JTP18 Electric Single Oven
Oven Flashing "F2"
Not sure of model number, refers to manual PLT083-2, probably high temp sensor, if correct would like loaction of sensor and part # and place to purchase, live in Louisville,Ky.
Thankyou in advance,
Terry Thomas
  • Nhamman Oct 01, 2008
    Same problem. The stove has been unplugged for two days. I plug it back in can the sensor still think it is hot? I can't get the door open, it is still locked.
What does the flashing signal F 9 mean?
Posted on Oct 27, 2008
  • 943 Answers
Hi thanks for the question. F2 means a high temp, and to look at the oven sensor circuit.I would replace the sensor. not too expensive and try . the other solution is the circuit board. so try the sensor. thanks the appliance doc
Posted on Sep 29, 2008
Oven is showing f2 what is happening
Hi Nancy:
Error Code F2 indicates a loose or broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced.
Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Hope this helps; thank you for using Fixya. Keep in mind that your feedback is important, leave us some testimonial comment.
Nov 24, 2011 | Magic Chef Ovens
I was letting my oven self clean and then it has started beeping went and lookfed and F2 is flashing what does that mean
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
Nov 15, 2010 | GE Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Flashing F2 Error code
Hi There
I have found this for you to read and hope this will help you. Let me know how it goes.
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Dec 30, 2009 | GE Profile JTP18 Electric Single Oven
F3 and flashing on Kenmore oven
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 18, 2009 | Kenmore Ovens
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
I have a GE model JKP13 and it keeps going off, beeping and flashing f2 or f3
HI, the oven has experienced a very high temp due to a failed sensor. Check sensor harness and harness connection between oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
Next. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Look for welded relay contacts as well on the control and sensor. replace, both the control and temp sensor if weld spots are visible.
Aug 04, 2009 | GE JTP45 Electric Double Oven
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
Oven showing F2 fault
tire, if your model starts with 911. the code stands for an overtemperature condition. I would start with the temp sensor, this is the probe inside the oven cavity, part # 334300. You can ohm it out, should be around 1100 ohms at room temp. This is for model number starting with 911. Catriver..post back.
Apr 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
343 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
