Question about Toshiba Televison & Video
Toshiba CE35f15 TV
TV was working fine for 10 years, a couple days ago picture went black except for a 1/2 wide horizonal line across the center of the tube. Audio works.
  • 3 more comments
  • tony golato Sep 30, 2008
    Thanks Guru.
    I will give your suggestions a try. Is there a schematic I can find somewhere to narrow down my seach for the IC and /or caps?
    Totally appreaciate you help and quick response!!!
    many thanks again,
    Tony
  • tony golato Oct 01, 2008
    Hi Dan,
    I am having difficulty locating the IC TA8427 (IC301)on the board, Would you be kind enough to point out on the photo.
    Hi Dan,
    I finally located the 7 pin IC TA8427k it was behind the heatsink near the center of the board.(beneath the green wire in the picture) It was on the board position C314 and not IC301 is that ok? I also found IC TA8426 on the board any interest in that one? BTW the TA8427k at a local electronics shop is only $3.43 and I will pick up today.
    Thanks for your help and I'll keep you posted,
    Regards,
    Tony
  • tony golato Oct 06, 2008
    This weekend I relaced the IC TA8427 with a brand new one and the same problem exists.
    Thanks,
    Tony
  • tony golato Oct 08, 2008
    Hi Dan,
    Thanks for all your help, it was greatly appreciated! I decided it is time to buy a new TV as I already got 10 plus years out of this one.
    Many thanks again,
    Tony
  • 4,234 Answers
This is a vertical circuit problem that is either bad connections on the vertical IC or a defective IC. If you can solder, you can fix this yourself. Look for a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC. There may be defective caps in the circuit as well, but those don't usually cause complete vertical failure. If the picture does not return fully, update this and we'll continue on to the next step.
Dan
Posted on Sep 30, 2008
  • 1 more comment
  • ABRsvcs Sep 30, 2008
    OK. The vertical IC is actually marked TA8427. On the board it will be IC301. This part runs about $6 on the web.
    Keep me posted.
  • ABRsvcs Oct 01, 2008
    C314 is in the same circuit but is actually a capacitor located close to that designation. You should see IC301 written on the board close by. Replace the IC and let me know what happens.
    Dan
  • ABRsvcs Oct 07, 2008
    If replacing the IC didn't help, we now need to look at the supply voltage to the IC. If you feel comfortable with this, you now need to measure the voltages at each of the pins on the IC with the set ON. Please note that there are high voltages present that can be dangerous. If you don't feel comfortable with this, please do not attempt it. Post the voltages here for each of the pins. These should be measured in reference to ground. Usually I attach the black lead to the tuner for the ground.
    Dan
TA8427K IC overheat within a minute also pin 6 measures 52 volts when it should be 24volts no vrtical
Posted on Jun 19, 2010
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
Same white lines on top of screen
you still go the warrenty on it
Jun 04, 2009 | Toshiba 32D46 32" TV
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
Mar 31, 2009 | Televison & Video
My older Toshiba TV is showing horizonal lines on upper screen.
maybe dust in the back of set try giving it a hoover out but unplug first
Mar 19, 2009 | Toshiba Televison & Video
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Televison & Video
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
done tv needs professional help. the Electron gun internally is no longer capable of spanning the entire screen. Not likely anything can be done outside of professional help
Aug 16, 2007 | Toshiba CF36G40 36" TV
Televison & Video Logo
481 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
