Question about Denon Audio Players & Recorders
I have a Denon AVR1603, recently I plugged computer in AUX connections at rear (not loud) and it kept tripping out. Eventually it tripped and now the the on/standby light fashes but nothing else happens. I have tried resetting by holding speaker a & b whilst turning the unit on but apart from th flashing LEDs the unit still does not work.
    Genius:
  • 1,550 Answers
The LED flash indicates that unit goes into protection. Check the power transistors, the 0.22 ohm or 0.47 resistors in the output of the transistors.
SAM ANDERSON
Posted on Sep 30, 2008
  • Denon Master
  • 19,396 Answers
Try leaving the unit unplugged for half an hour.
If it does not work there may be an internal problem, like a blown component.
Posted on Sep 29, 2008
  • 10,594 Answers
Receiver got problem in amplifier section that's why doesn't power up and Standby LED flashes.
Please contact nearest Denon service center for proper repair of unit.
Speedqueen heavy duty extra large capacity trips power
Does this happen simply plugging it in? Or is it when you try to operate it? If it occurs as soon as plugged in, you may have grounded something inside the unit during transport that is causing the power to trip. Or you could have a faulty breaker. If it is when trying to use it, determine if the circuit load is adequate for the unit. There may be other items on the circuit causing it to overload when operated.
Aug 01, 2016 | Washing Machines
No problem with hotpoint electric range til I went to start oven, breaker kept tripping & making a popping noise
From having a Hotpoint myself, I can think of 2 possibilities.
Obvious answer would be electrical problem. If it trips the breaker you probably have a loose wire or a bad plugin socket. Did you buy a new "pigtail" plugin socket or did you use an old one when you got the stove? They say to buy a new one each time. If this is your first problem with this then your circuit can probably handle the load but see if the circuit that tripped says 30 or 40 amps. Also check to see if anything else is on that circuit besides your stove. There shouldn't be anything else on circuit. You may even have a bad circuit breaker but that seems less likely.
Second possibility is a bad baking element at the bottom of stove or bad heating element on top. When mine went bad, it made loud popping noises and sparks were flying. After that, the rest of the stove worked but not the baking element. I had to replace it for about $50.
My bet is on a loose wire. Be careful and unplug everything before you check! See if it's not fully plugged into the socket and see if the 3 or 4 wires coming from the thick plug wire are all tightly connected to your stove.
Jan 12, 2014 | Hotpoint RB757 Electric Kitchen Range
Connect to computer
On the back of your computer should be an audio out jack, generally marked Green. You can get a 3.5mm jack plug to two RCA plugs. The jack plugs into the green socket and the two RCA into an Aux/CD socket of the Denon. If you have other speakers connected to that Green Socket you can get a headphone splitter socket and plug that into the green socket.
Jul 13, 2013 | Denon D-M50S CD Shelf System
Hi is it possible to connect a laptop to a denon 700aedab for music playback
HI, very possible. Just follow this instruction:
All yo need to use for the connection is to get an RCA TO STEREO JACK HEAD (use the google image to see the type of cable).. Connect to denon 700aedab, make sure that the denon 700aedab is on either aux, tunner,video,etc. Those auxillary options on your denon 700aedab.
Connect the RCA into the aux of the denon 700aedab and connect the small jack head into the laptop ( where you plug in earphones),and play and enjoy your music.
If it does not play with aux try tunner, or video, one mustplay,and if it does ot play any, that means either the port of your laptop or the denon 700aedab port is faulty.
And don't forget to connect the speaker,because diffidently you will sure hear absolutely nothing with out the speaker.
Feel free to pass your comment .
Thanks for using fixya.
Jan 10, 2011 | Denon Audio Players & Recorders
Our dryer was making a loud squeaking noise for a while now it is tripping the circuit breaker as soon as it is started what do you think is our problem.
The drum rides on a bearing in the rear which cause the squeal. The squeal eventually cuts into the bearing and the whole drum begins to rub against the heating element. This causes the breaker to trip.
How it works: GE clothes dryer
Jan 05, 2011 | GE Dryers
Unit''trips'' off shortly after powering up
Disconnect ALL of the speaker wires from the back.  Turn it on again, if it still trips, then the unit needs to be repaired.  If it does not trip with no speaker wires connected, turn it back off, connect 1 speaker at a time and turn it on, when it does trip, that speaker that you just put on has a short somewhere, it could the be the wire or in the speaker.
Mar 29, 2009 | Denon AVR-3300 Receiver
How Do I Connect My Dell Laptop to a Demon AV Receiver
use a 1/8in stereo to two male RCA plug to connect from your computer headphone out to an input on the Denon such as AUX or CD
Jan 25, 2009 | Denon AVR-587
Denon avr-1403/483
Denon AVR-1403/483One of the speakers when connected trips the units power off.
Disconnected it and it works OK without that channel. Connected a different speaker and wire to that channel and it does the same, trips power off. It's acting like a when two wires are shorted. This is not the case as I have tried different wires and speaker. Not sure whats going on. Presently running system without that channel. Hope someone has an idea.
Oct 19, 2008 | Denon AVR-1403 Receiver
Cut off :|
same eyaaaaaaaaaaaaaaaaaaaaaaaaa
Aug 24, 2008 | Philips FWC399 CD Shelf System
408 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
