Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LG dishwasher does not seem to clean items on lower rack
Unit does not clean items on lower rack. i see there is a cycle that only cleans the upper rack. does the unit need to be reset or something of that sort. to my knowledge we have never used this upper rack cleaning cycle.
  • Haywood Parrish Nov 12, 2008
    I have the same problem and I can only guess that the flimsy gaskets underneath the apparatus at the bottom of the tub need replacing. I took mine apart and found those gaskets in pretty bad shape. I've only had the unit about a year and a half and I think it is too soon for gaskets to need replacing. However, nothing is clogged, the upper rack is getting clean and too many dishes on the lower rack are getting clean for me to think that it is operating in the "upper only" mode.
    If you get a solution, email me at hwparrish@sbcglobal.net
  • Haywood Parrish May 11, 2010
    Another posting says the reverter motor is either stuck or broken. The other posting seems to indicate sticking is the problem.
  • 423 Answers
Can you tell me if the problem was fixed by the original posters?
The multi-level wash direction feature uses a check valve just below the mesh filter asembaly and is driven by a vario motor underneath the check valve. By removing the mesh filter (10 screws and the lower spray arm) you expose the check valve. It is very close to the pump that empties the water through the drain hose.
High probability problems: -The Check Valve could be jamed/stuck. -Also, the Vario Motor could have failed
Please respond back with the findings on this problem. Thanks!
Posted on Mar 30, 2009
Why doesn't my Bosch SHU43 c06uc dishwasher have any cleaning force?
With your dishwasher empty, roll out the bottom rack. The feed line for the upper spray arm runs from a pump outlet directly behind the lower spray arm spindle. This tube runs up the back wall of the dishwasher and mates with the upper rack when it is pushed in.
This feed tube simply snaps into place in the bottom of the machine. It is a high pressure line that makes an immediade 90-degree bend towards the rear of the unit. They have a tendency to pop out. When and if it does pop out you get almost no water coming out of the upper arm and you lose effective pressure in the lower arm, too. The cure is to push that feed tube back down firmly into the port until you hear it snap into place. While you have the lowere rack out it is a good idea to clean the intake screen out and check for any debris in the intake well.
May 24, 2014 | Bosch Dishwashers
Suddenly not cleaning even after two cycles. Upper rack seems
run the machine at the hottest tempture with two tablets empty.You do not give enough information so im only trying to help yours adrian;;;;;
Jan 22, 2010 | Dishwashers
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Model gu2700xtss1, upper rack not clean at all,
I am here for the exact same reason. Mine is less than 3 months old. This may be a recall item. I bought, and paid more for a kitchen aide for the name and reputation.....Where can I find the model number?
Feb 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Lg LDF6810ST dishwasher not cleaning top rack
Almost all of the problems mentioned above will be solved by having the owner buy a name brand detergent powder (like Electrosol or Cascade) and using a little less than you think you should.
For those who continue to have problems with poor cleaning, you need to remove the lower spray arm (pull straight up firmly, then out) and then remove the 9 screws that hold the filter in. Using a flashlight, inspect everywhere in the sump area (be careful of broken glass!) Remove all debris and especially look for something blocking the white check valve that is driven by the Vario motor to control the alternation between the upper sprayer arms and the lower arm. Reasemble and test.
If inside dishwasher is a mess with white mineral deposits, recommend you place a bowl filled with white vinegar on the rack of your empty DW. Start a quick cycle with no detergent added.
Check out how clean it is when you are done!
If you have problems after this, please post back what you are seeing.
Good Luck!
Oct 02, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG dishwasher wont clean top rack dishes
If the unit is cleaning the bottom dishes normally, try unplugging the unit for 5 minutes to reset the control board.  If that doesn't work, then the control board needs to be replaced.  The problem is that control board is not diverting the water to the upper wash arm during the cycle.  Possibly a program problem
May 30, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Mar 25, 2008 | Dishwashers
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
634 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
