Ecoquest Living Air Classic Air Purifier
Problem for Ecoquest Living Air Classic Air Purifier
XL-15S, NO OZONE
By fleamrk on Sep 29, 2008
I'VE CLEANED THE FILTER, STILL NO OZONE. THE FAN TURNS AS IT SHOULD. AND THERE IS NOT A STATIC SOUND COMING FROM THE UNIT.
Solution #1
posted on Dec 23, 2008
Not Rated)
JSEhandyman
Rank: Guru
Rating: 91%, 126 votes
Hello fleamrk,
Several possiblities here. Not static sound means the plasma discharge plates aren't energized.
1) Missing, cracked or defective discharge plate (you say you cleaned the filter - did you mean the lint screen in back, or the glass or white ceramic plate inside)? No plate, no ozone (O3) production.
2) Bad connection in the high voltage leads*.
3) Bad electrical components*.
*I'm not an electrician, and recommend that only qualified personnel troubleshoot high voltage electronic, both for safety, and for preventing further damage to circuitry. Visible problems, such as corroded or broken terminals that can be swapped when it's de-energized (unplugged) is one thing; having to dig deeper into the electronics is something that I expect to rapidly end up costing more than it's worth.
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Living Air Classic
Questions and Unsolved Problems for Ecoquest Living Air Classic
Do you recommend Ecoquest Living Air Classic Air Purifier?
Answer
Answer
I have a Classic Living Air model XL-15C. I keep hearing a loud rattling noise from inside. I... (More)
Answer
no high voltage to grid after 5 minutes operation
Answer
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky... (More)
Answer
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is... (More)
Answer
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Living Air Classic...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
