Question about Garden
Lawn boy mowers
My lawnboy mower is running at full throttle?
    Problem Solver:
  • 18 Answers
Check for stuck float in the float case youll find a small needle valve which is adjusted.. by the level of fuel when it raise the float the float lifts the neddle up to allow fuel to pass to the intake it may stuck..or check your governer on top of your fly wheel.. if your have a standered carburator with a pump,, that bolts to the side..similer to breggs and straton... their a spring and a short thin rod that opreates the govener..if the spring is streched or the thin rod is bent out it will cause the mower to run high speed....heres a idea,, you know a carbarator. makes a engin run fast or slow..it has to have something to adjust the speed on it..start their first..
Posted on Oct 12, 2008
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 | Garden
Rj19lm plug gap for a 195cc 4cyl lawnboy
As a starting point in my shop i always use 0.30 in. For all my mowers
Oct 11, 2014 | Lawn-Boy lawnboy" Mower Blade 21"
Oil mixture for 1985f series 2 cycle lawn-boy mower
Contact your dealer ! but 32:1 sounds correct. 8 ounces of Lawnboy oil to two gallons of gasoline ....is 32:1, 8 ounces of oil to one gallon of fuel is 16:1 for the real old lawnboys,
When Toro bought out OMC,and started using Tecumseh mowers,the ratio changed in the late 80's or early nineties ! IIRC :o)
Jun 11, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy mower will not idle up under load
the lawnmower is not designed to idle with a load on the engine, it needs to be operated at full throttle
Apr 10, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Rough low throttle on Lawnboy Dura Force Pro 6.5
IT HAS A WEAK SPRING THATS ALL IT IS
Sep 28, 2009 | Garden
Lawnmower throttles up and down
locate the carberator the unscrew the 1/2' bolt under the float bowl to remove the bowl empty and clean out the bowl reinstall making sure the o-ring is centered for the bowl it acts as a sealing ring for the bowl screw the bolt back in and tighten, this should solve the surging problem.
Sep 12, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
How do i install the spring throttle on a lawnboy 10323
take the air filter off the spring is attached to the govenor rod to a fixed arm once attached the arm can be bent to tighten the spring or bent the other way slow the speed tighter the spring faster the speed there is another rod attached to the govenor rod to the throttle
Jul 01, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
439 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
