Question about Dell UltraSharp 1703FP Flat panel TFT 17" Monitor
Inoperative monitor This has now (4 years old - 3 months apart failures) happened on both monitors: Screen displays what Dell calls Self Test Feature Check. This box with 2: Digital Input.... with 4 color bars roams across the dark screen. Online Dell support talks about Cables and video card from computer, but when the inop monitor is moved to the other Dell computer, same problem. When any good monitor is moved to the computer that had the inop monitor, every other monitor has worked. "Digital Input" is interesting, since we are operating with the blue cable, which I thought was analog, and not the white cable, which I thought was digital, but I probably have that concept wrong. I tried Dell support, but since this is home, and not business, I get India, and all I hear is "budget for a new one." One opined that he agreed with me that some board in the monitor was not recognizing the video signal. thanks
  • 3,940 Answers
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Posted on Sep 29, 2008
  • 660 Answers
If this monitor has multiple input types have you tried the other input modes IE if using DVI input switch cable and try on a HD15 system, if it works then great...... hopefully you can swap it so that you have a working monitor on all your systems
there are more than 2 different types of cable for a monitor, and there are more if you include MAC..etc....
the main ones are
DVI http://en.wikipedia.org/wiki/Digital_Visual_Interface
HD15 http://en.wikipedia.org/wiki/HD15
BNC5 http://www.maplin.co.uk/module.aspx?tabs=n&ModuleNo=97368&ma=VGA%2015(M)-BNC%201.5m
there are others around, but these are the most prevelant
Monitor screen shows side to side display instead of up and down. How do I return to up and down display
Dear,
To rectify your problem, Perfrom these steps.
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of the computer.
  3. Turn on the monitor.
Mar 13, 2012 | Dell E228WFP Monitor
My monitor is blank it just keeps saying self check its a dell flat screen
If it shows "Self test feature check" the cable (VGA / DVi ) is unlplugged on the computer/ tower. Check the cables it may be loose. If not, try replacing the VGA/DVi cables. The LCD is good since it was able to display the self test feature check.
Hope this helps.
Mar 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My monitor is brighter on the lower left side than on the rest of the display?
NOTE : steps below are only for a Dell monitor
There could be two reasons for the same,
1. The monitor settings are bad or
2. The monitor has gone bad.
Request you to disconnect the monitor signal cable from the back of the computer (cable with the blue jack)
A self test feature check would run on the screen. If the screen is bright in the feature check . The monitor has gone bad and needs a replacement.
If the screen appears ok in the self test . Press the menu button on the monitor and select factory reset.
Thanks
Proton
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
Hello I have a monitor DELL E228WFP and it turns black after a while. I have it about 1 year, and it turns black for no reason. I wan't to know how to make the flash light test on my monitor.
Okay, there is what is known as a Diagnostic Partition in all Dell computers. When you turn on your computer you need to Tap F12 when you see your BIOS load (which is the first thing you see on your screen when you turn on your computer.) You will then see several options, if you did it correctly, and the one on the very bottom usually says something along the line of "Boot to Utility Partition" and there will be an option for a screen test. Run it.
Please tell me if you need any further assistance.
Ryan Frame
Creative Energy Associates Technical Center
Nov 13, 2009 | Dell E228WFP LCD Monitor
Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
1. Turn off both your computer and the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jul 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Problems with Dell E176FP 17" LCD Monitor?
Kindly disconnect the monitor from the computer and power it on , if the screen is still blurry on the self test feature check , the monitor is bad.
You can press the menu button on the monitor and select Restore to Factory setting or Factory reset option. If the problem persists you can call LCD repair
http://www.lcdrepair.us/
Monday to Friday: 8:30 am to 4:30 pm
Central Standard Time
Phone :
469-521-7517
If you have purchased,the dell monitor seprately from the computer, it carries a three year replacement warranty.
Thanks
proton
Nov 21, 2008 | Dell E176FP 17" LCD Monitor
Dell Monitor goes blank, green light still on.
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Nov 20, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell172fpb 17" monitor
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Sep 04, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Computers & Internet Logo
613 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
