Question about Mitsubishi VS-50605 50" Rear Projection Television
Rolling screen my tv screen is rolling when you turn on the tv....someone told me it was the regulator...I was wondering if you think that is what is wrong with it??? Is that something that should cost a lot of $$$ to fix or what do you think!!! I took the back off and noticed that the green tube was a little shaky like when a light bulb is fixing to go out!!! Thanks Lannie
  • 927 Answers
Good Day; lanniejo;
1. VERTICAL ROLLING, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. REPLACE C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. REPLACE C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
It should not be that costly, always get an estimate, if you can't repair it yourself. Don't worry about the light bulb, it should be okay, as long as the picture color is ok. Good Luck, big IRISH.
Posted on Oct 14, 2008
Problem rolling bars
It should be a main power regulator baord fault. Contact any service technician.
May 22, 2013 | Panasonic TCP50U2 50 in. TV
Where is the vertical hold button
This set has no vertical hold control---is picture rolling left right or up down?
Mar 10, 2012 | Hitachi 57F500 57" Rear Projection...
Where can i get a plexiglass screen?
I have a P46921 46 in rear projection television. I brought it in and they told me it was the processor board (main control board with programming) that wasn't letting the TV turn on and was quite an expensive repair. I now have the parts back and was wondering if someone could use them. I know that some people were looking for the actual screen found behind the plexiglass or what looks like plexiglass. I have all the parts and was told that it worked beautifully until it decided it wouldn't turn on again. Anyone interested, please drop me an email at jforest7@gmail.com.
Thanks.
Oct 11, 2010 | RCA P46921 46" Rear Projection Television
2000 pont grand am se- rear passenger side window rolls down fine but wont roll up. wondering if it's the window regulator.
Probably, they are real junky on those cars, I know, I have one!! I have replaced 3 of my 4 regulators!! and one motor in the drivers door.
Nov 27, 2009 | Pontiac Grand Am Cars & Trucks
Turns on but nothing else works
Your probably correct, however, the tuner also has serial/data lines going to it so the tuner can cause that problem but highly unlikely.
Feb 03, 2009 | Polaroid FLM-2632 Television
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Magnovox TV
I've taken the TV to a Magnavox repair shop.
Apr 29, 2008 | Televison & Video
Sony BRAVIA KLV-40U100M Issue
Just bought the KLV-40U400M Sony Bravia Monitor. Did you fix the turn on turn off problem? How much did it cost, labor/parts?
I'm thinking I better get the extended warranty although I wonder if the board will continue to go bad year after year.
I was told the tv could be replaced but w/someone else's refurbished tv. I was very unhappy w/that response.
So how's your tv today?
-Capri
Nov 03, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Lines on tv
All of the convergence IC's should be replaced at the same time! Its not a job for a user to do without the experience. This repair should range in the way of between 250 all the way up to 400 bucks. good Luck
Jul 31, 2006 | Samsung HCL4715W 47" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
