Question about Dryers
Dryer belt broke and the wheel tying the belt to the motor somehow come loose and was laying on bottom of dryer when I went to replace the belt, need schematics to figure out how to put wheel back in place.
    Novelist:
    Champion:
  • 261 Answers
Below the motor pulley is two sets of parallel slots and some notches running perpendicular to them. Look at the tensioner, the piece that is laying on its side. Notice opposite of the roller is a flat surface with flanges that line up to the holes below the motor pulley. Ok? Alright now we want to scoop the front into one of those notches and it will hold. Now the belt goes over this roller on the tensioner first pushing slightly away from the motor pulley causing enough slack to loop it around the motor pulley so it goes over then around. Have someone hold the drum and steady so you can reach in, ps make sure the dryer is unplugged.:)
Ok here is a site I use to get illustrated, Look it over and punch in your model so you can see roughly how to get er done. Notice item 53 this is on my dryer, use www.apdepot.com.
Posted on Sep 29, 2008
The small belt in the middle of the drum broke. After I pulled the drum off I noticed a small plastic wheel on a metal bracket loose in the bottom of the dryer. I can not see where this reataches and I...
its called an idler arm, it attaches next to the motor as this is what keeps tension on the belt so it will stay tight on the drum. If I remember correctly there is a slot on the bottom of the dryer close or right next/past the motor, slide it into that slot, with the small plastic wheel up next to/by the motor. I am attaching a diagram for the belt it will help. Good Luck and I hope I helped Tim:
http://www.applianceaid.com/images/belt-config.JPG
Remember the belt should ride in the middle of the drum and the back of the drum is lipped and should go behind the drum rollers. Once the belt is thread it will be tight and the idler arm will not longer be loose.
Mar 12, 2011 | Whirlpool LER4634J Electric Dryer
Loud sqeeling noises when running. Sounded like a belt slipping. Dryer died all together and smells of burning rubber. Suspect a loose or broken belt. How do I change it?? --Dave
Check and see if the belt slipped off the motor pulley broke or wrapped around motor pulley. Check the idler pulley (large white wheel end of motor) Loose?
Oct 16, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Started making grinding kind of noise a couple weeks ago...just now stopped spinning.
there are to tub wheels that hold the front of your drum up ck them but it sound like your tensioner has went bad it is a spring with a plastic wheel on it located beside the motor in the bottom and back of your machine. It sound like the tensioner went bad a probably broke your belt replace both
Aug 08, 2010 | Roper RES7648E Dryer
Kenmore dryer drum will not turn.
This is commonly caused by a broken dryer belt. If you post back with your model number, I can explain to you how to verify and/or replace the belt.
Aug 29, 2009 | Kenmore 63942 Dryer
Motor is running but not turning drum to dry the clothes. We removed the back of dryer to see if maybe belt slipped or broke but can not see any belts and do not want to start removing a lot of screws...
Look from the rear, near the bottom. The belt wraps around the drum, and near the bottom is a tensioner that keeps tension on the belt. If it is broken, you'll see it laying on the floor of the dryer.
Jul 03, 2009 | Estate EED4300TQ Electric Dryer
Need to install drive belt- lady kenmore dryer..loop designation
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jun 25, 2009 | Dryers
Belt Broke and pulley bracket came loose, where does pully belong
It goes into the front of the motor on the floor with the wheel to the left. You insert the belt between the idler bracket and loop it over the motor pulley.
The ribs of the belt need to be up against the drum for grip. It is best to have a person hold the drum while you do the pulley. Here is a page that shows various belt routings on different machines, yours is bottom right.
Jun 09, 2009 | Whirlpool LER4634J Electric Dryer
My Whirlpool dryer belt broke.
You should be able to reuse the idler pulley unless it is physically broken.
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Belt broke
Buy a new belt. Insert the idler pulley into the slots under the motor pulley. The wheel should be on the left side of the motor as you face it.
Put the belt around the drum, then through the idler roller. Then over the motor pulley.
Mar 11, 2009 | Kenmore 63942 Dryer
How do you replace the drive belt on Whirlpool dryer?
What is the model number of the dryer.
Nov 14, 2008 | Dryers
Dryers Logo
120 people viewed this question
Top Dryers Experts
