Question about Air Tools & Compressors
Coleman powermate inflationmate pump
Turn on compressor, pumps air into the tank, turn off compressor, can hear the air blowing back through the pump,tank will not build up pressure.
  • 2 more comments
  • Anonymous Apr 28, 2009
    Compress runs but will not build up any pressure. How do you order new rings.
  • Anonymous Mar 15, 2014
    compressor starts up good then almost locks up and smokes the belt. It will finally pressure up but takes a long time.
  • Anonymous Mar 22, 2014
    Not enough pressure in tank
  • Anonymous Mar 27, 2014
    When I hook up my air hose to the compressor I get nothing, but there is pressure in the tank.
  • 104 Answers
The ring is gone on compressor. You can buy replacement pistons and rings from colemen. Comes with instructions.Good luck
Posted on Oct 26, 2008
Coleman no longer makes the Inflationmate, nor does it list any parts for it on their website
Posted on Jul 22, 2009
Coleman Powermate VP201 will not go above 40 lbs.
Hi mjschulte815
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will **** you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Oct 17, 2012 | Coleman Model Vp0200406 Powermate...
Can,t find replacement parts for this lemon thanks
ww.ppe-air-compressors.com/coleman-powermate-air-compressor... - CachedColeman Powermate Air Compressor Parts, Breakdowns & Manuals. Choose Your Model # Below to find Breakdowns & Repl.
I just browsed the net and found several sites that sell coleman parts. Above is just one I copied and pasted. If your unit is older, if you know the type of pump you can search for that. eg. (debilvius) A lot of compressors have the same pump under a different name like Coleman, Sanborn etc. I have found some units that are just so old they are obsolete and parts just aren't available.Hope this helps. Good luck!
Aug 16, 2011 | Coleman Air Tools & Compressors
Schrader valve leaking air blows breaker
Sound like the tank check valve is bad. replace it. located where discharge line from compressor goes into tank.
Jun 26, 2011 | Coleman Powermate 27 Gallon Air Compressor
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Need piston rod for rep0200604 compressor
A search of your model number turns up a powermate compressor. Unfortunately the piston rod is not available as a seperate part, you have to order the entire pump/motor unit. The only place I could find it was at this link: http://www.ereplacementparts.com/powermate-vpp0200604-single-stage-oil-lubricated-air-compressor-parts-c-117046_117047_117049.html.
Dec 23, 2010 | Coleman Proforce 6 Gallon Air Compressor
Unloader valve releases a lot of air when compressor shuts off and will not let the motor kick in blows breaker
This is usually a problem with the check valve. The unloader valve on your pressure switch is designed to bleed the pressure off the head of the compressor. With a leaking check valve the pressure isn't relieved from the head and the pump can't turn causing the motor to overload and blow the breakers.
To troubleshoot your problem try the following:
Trace the 1/4" line that connects to the unloader back to the tank. You'll find a fitting there. Remove the lines and then the fitting. Sometimes cleaning that valve will alleviate the problem. If not you need to replace the check valve.
Hope that helps.
-under_psi
Mar 18, 2010 | Coleman Powermate 27 Gallon Air Compressor
Coleman Powermate Inflationmate portable 4 gallon compressor. Model VP0200406. See image at http://www.yotatech.com/f5/how-fix-compressor-111315/ . Coleman lable on back says 120 v, 15 amp, single phase,...
Use a 15 amp 'time delay fuse'. Any time you start a motor, the inrush current will blow a regular fuse. Motors pull high current to start then drop to normal after 1 or two seconds. The time delay will fix it up!
Sep 20, 2009 | Air Tools & Compressors
Coleman powermate 27gal 5hp air supply line and regulater gets very hot and blowes off hose
Is a shroud of any sort been took of ? is there oil in pump assembly ? Is there a fan on this model? At what pressure does the compressor stop pumping (should be less than 135psi aroud120psi) are you using it over it's duty capacity ei:sandblasting....?
Jun 04, 2009 | Coleman Powermate 27 Gallon Air Compressor
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
Air Tools & Compressors Logo
1,132 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
