Question about Mitsubishi WS-55819 55" Rear Projection Television
WS55819 How do I remove the lamp from rear of TV? We have been told this is reason tv is turning itself off but have been unable to remove part. thx Brenda
    Master:
  • 726 Answers
Open the tv there will be three lamps inside around black stands and simply unscrew them
Posted on Sep 29, 2008
Power keeps going on and off
Model number posted in question that is KDF-60SX955 shows it is Sony dlp tv, if tv shuts down and turns On itself then reason is weak lamp that is near to end of its working life and need to be replaced to fix this issue.
Lamp replacement procedure is written in user manual and its easy. Please buy Sony original lamp for good quality picture in tv.
Let me know if you have additional question.
Thanks.
Apr 18, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Sep 16, 2009 | Panasonic PT-60LC14 60" Rear Projection...
I have sound, but no picture
I am finding a lot of people's lamps are going out. This maybe your problem too judging from what I have read above.
There are replacement lamps. They used to be pretty expensive but they are somewhat reasonable now. Below is a site you can order a new lamp this should fix the problem.
But before you order make sure that all the cables in the back of the television are in the right order. Red and White are audio while Yellow is video. A lot of people are unable to distinguish the yellow from the white.
If you have the other cables such as the blue and the black make sure the blue is with blue and black is with black. They are hard to see sometimes in a poorly lit area like behind a TV.
If everything is hooked up correctly.
Your next bet is the lamp replacement. Replacing the lamp its quite easy to do. Just remember to reset the TV lamp timer. Consulting your owners manual should help.
Here is the site for lamp replacements. You also can do your own search for lamp replacement.
http://www.purelandsupply.com/GeneralSearch.aspx?search=Samsung%20HLN617W
Jul 13, 2009 | Samsung HLN617W 61" Rear Projection HDTV
TV turns off by itself
Check the interlock switch on the rear lamp cover. Sounds like the cover might not be seating completely, allowing this safety switch to shut the TV off. When you remove the cover, it's just to the left of the big black plastic ventilation guide for the lamp, and it's a little tiny blue lever that moves up and down. Make sure the wires going to this switch are OK (not pulled out or 'hanging by a thread').
Jun 09, 2009 | Samsung HL-S6187W 61 in. HDTV
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Realistic Lamp Cost ??
139.00 seems reasonable for a replacement lamp. is that the only problem that you are having or are you hearing a squealing sound and then the tv cycles off?
Dan
Aug 29, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Power light flashing????
Count your flashes and call the RCA hotline and they will be able to tell you what the number of flashes says about your tv. My lamp needs replaced and I was told 3 to 5 flashes meant the lamp was out.
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi WS-55819 55" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
