Question about Orion HCCA 275G4 Car Audio Amplifier
Orion HCCA 275g4 amp
I need to know what the sequence for the positive and negative on the speaker wire harness are, mine are scratched off and i can not indentyify positve from negative. Please help!
  • 631 Answers
I have a orion xtr 2150 and a hcca 10.4 what is the best way to wire this combo?
Hello. Quick answer...bad sub and amp combo due to fact that your sub needs a lot more power than this amp can produce (I'll explain later). But here is how you can do it: You can wire this dual 4 ohm sub in parallel or series. Parallel wiring would be to wire two the positive terminals on the sub to each other and wire two the negative terminals on the sub to each other. Thus wiring down the sub to 2 ohm. This what the amp would see. Series wiring would be to wire the positive and negative terminals on the same side of the sub to each other. Then wire the positive and negative terminals on the other side to the amp. Thus wiring the sub to 8 ohm. This what the amp would see. Illustrations can be found here: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=42#results
Your sub specs are 1500 watts rms (how many watts your sub needs to operate efficiently or its minimum requirement. It has the a peak wattage at 3000 watts that it can accept in short duration. Your amp can only produce 300 to 600 watts at 2 or 4 ohm respectively. So you would be greatly under powering the sub which would produce a weak unfulfilled sound. You need an amp that produces a true 1200 to 1800 watts rms. There is a great selection out there.
Sep 01, 2012 | Orion HCCA 10.2 Car Subwoofer
How to bridge a Orion 250 hcca amp?
Should have a diagram on the bottom of amp or where you hook up the speakers to amp......Its usually the two outside speaker connections.....just be sure to hookup negative to negative and positive to positive.let me know if this helps.........
Mar 25, 2012 | Orion Car Audio & Video
Hi were can i find a schematic diagram for orion hcca 275r Thank you
i am looking for the same manual. Did you have any luck finding it?
Mar 22, 2011 | Orion HCCA 275G4 Car Audio Amplifier
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Power wire keep blowing fuses
you need to go tho a block fuse which will be able to handle more load but will still give way before the amp its self would get fried i recommend a 75 fuse or higher
Feb 21, 2009 | Orion HCCA 275G4 Car Audio Amplifier
Old schoool orion amp 250-hcca
Wiring Codes for SX and HCCA
Black/Orange = Right Negative
Black/Yellow = Left Negative
Blue = Remote Turn On
You can remove the bottom of the amp and the colors can be deciphered as to which goes to which pin in the plug. Go to this link on AmpGuts for a reference.
http://www.ampguts.realmofexcursion.com/Orion_HCCA250/
And here is a link where you can buy a new plug on ebay for $25.
http://cgi.ebay.com.my/ws/eBayISAPI.dll?ViewItem&item=110093583828&indexURL=
Dec 05, 2008 | Orion Car Audio & Video
Orion 250G4
Generally to bridge an amplifier you need to insert the positive wire from the sub to the positive wire on the first channel. And then insert the negative wire from the sub to the second channels's negative terminal.
Apr 22, 2008 | Orion HCCA 225G4 Car Audio Amplifier
Orion 275g4 Hcca amp
this actually could be your amp...try turning the gain down slowly and you will hear the bumping either stop or become morelike music background thanmusic foregroud. i had this problem with an older amplifier and i fixed it by getting a larder power/ground wire size and decreasing the gain a little.
Sep 03, 2007 | Orion HCCA 275G4 Car Audio Amplifier
Car Audio & Video Logo
240 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Robert marquette
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
