Question about Whirlpool Refrigerators
I have a whilpool ed22rf fridge the icemaker cycles but no water goes to the icemaker. i have water @ the fridge,dispenser,and @ the valve
  • 943 Answers
Hi thanks for the question. A small tube goes in the ice maker it directs the water in the tray .Some times it will freeze up . check that if not frozen the ice maker water valve is the source of the problem thanks the appliance doc
Posted on Sep 29, 2008
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
May 15, 2012 - Uploaded by
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Aug 07, 2011 | Kitchen Ranges
TFX22KRCE AA \Hey guys! We have had GE forever and need some assistance. Above refrig with ice at all but icemaker cycles. Replaced icemaker with same results...icemaker cycles....
Check your valves. Are the lines to the I/M on the outside of the fridge and are they in good condition? If you can, switch electrical connections on the valves then call for water. If water enters the I/M then you probably have a wiring issue since you have already have replaced the I/M.
Apr 14, 2011 | Refrigerators
No water comming out from the dispenser
With a model number I can give you more specific direction however here is a start. Located at the back of the fridge, usually on the right side is the water valve. You can remove the plastic line that goes to the dispenser, not the supply line from the house or the line that feeds the icemaker. With this line disconnected activate the water dispenser and see if water comes out of the open side of the valve. If not you need to replace that valve. I hope this helps...
Jan 11, 2011 | Whirlpool Refrigerators
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side frigidaire ice maker not working
Check the water valve at the back of fridge. Are you getting water at the dispenser on the door? If so, the water valve may not be bad, but sometimes water will freeze in the tube that fills the icemaker. Pull it out from the back of the fridge and check it.Hope this helps !
Oct 08, 2017 | Frigidaire FRS26R4A Side by Side...
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
Check to see that you do have water to the water valve on the fridge. You can disconnect right where the water line goes into the valve on the fridge. Next, if you can, check power at the valve while activating the water dispenser. If you have power at the valve when activating then the water valve is bad. Let me know what you find.
Oct 10, 2007 | Refrigerators
Automatic icemaker
Have you made sure your water supply was good and a good steady flow of water is flowing in to the back orf the fridge?/ If you have then theres a small micro switch that opens a water valve at the proper moment of the cycle of the ice maker. This switch is inside the icemaker up against a small cam being driven by a small motor. The switch activates a small valve that lets the water flow into the ice maker.if the water flow is good its the switch or the valve. Good luck
Apr 16, 2006 | Whirlpool ET1FTTXK Top Freezer...
Refrigerators Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
