Re: machine shows an orange light and bleeps but does not...
This is RAM error. If you have tried to install new RAM module, probably it is incompetible with your motherboard or other RAM modules or BIOS RAM timings. Try to replace that module or restore to defaults BIOS RAM settings.
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
The machine has a defrost function, pressing the temperature button twice will start this and show a snowflake in the top right hand corner Press the temperature button twice, ( A snowflake will appear in the top left corner) this acts as a defrost button. F37 will probably occur more often if your machine is stored in a outhouse. or try thawing out the water pipe.
Yes that means the computer has failed POST. So yes, something has come loose or has got damaged.
"POST" is an acronym for Power On Self-Test. The POST process checks the basic system functions before attempting to load an operating system. It checks RAM, processor, drives, system interface, etc. If POST fails, the system will normally halt and may produce a series of beeps from the computer speaker which can help indicate the cause of the problem.
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it: Take the lid off the washing machine (2 screws at the back) *unplug first Locate the pcb, unscrew and lift above the washing machine with all wires in tact. Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires. Follow these back to the pcb and unplug plug in washing machine Turn on washing machine Only the on/off light should come on Whilst on, and being careful, plug back in the wires you unplugged VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
the noise you hear after the melody would you describe it as like a buzz or a small chainsaw? If so you have a bad color wheel assembly. If the noise is intermittent than your issue could be the ballast that controls the lamp. If you've already changed the lamp the next step should be the ballast.
