Question about GE Dryers
Will not dry clothes GE Model # DBLR333ET1WWW
  • 943 Answers
Hi. thanks for the question.First check the fuses in fuse panel 2- 30 amp fuses. replace them. 1 could be out.If the fuses are now ok and still no heat. The element is located at the back of the drum. To replace. Open the door 4 screws on the top lip remove. Lift top. 2 screws on inside of front panel. remove .Pull drum out remove belt, pull drum out . look for broken coil if so replace element .Thanks the appliance doc
Posted on Sep 29, 2008
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
I have a ge profile dryer model dpsb513eboww and the sensor dry doesn't work properly. It runs 3 minutes then shuts off. The clothes are still wet. All else works fine.
You should inside the driver and on the front or back wall will be the sensor: two metal bars that send an electric current through the clothing. When the dryer detects more current goes through, it knows the clothes are still wet and keep running. If the sensor bars are broken, disconnected, or dirty, it will read no current and think you put clothes in there that were already dry. Make sure those contacts are nice and clean. Failing that, you'll need to test the sensor circuit for voltage to see what the problem is.
Sep 19, 2009 | GE DPSB513BW Dryer
GE Washing Machine (model # GUSR2LOOT) drain problem
Check for a blockage in the water pump. If it does not drain first it does not spin. Check for power to the drain pump motor.If no pump blockage check the lid switch for continuity. No continuity, replace the lid switch.
Jul 03, 2009 | GE Washing Machines
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
GE DX4500EG6WW FROM SAM'S WILL NOT DRY CLOTHES WELL. This is the same as DBR463EGWW model.
Try using the manual settings instead of automatic; the thermostats responsible for checking humidity may be faulty. If you can get dry clothes this way, then you have an idea what has failed.
Mar 11, 2009 | GE DBXR463EBWW Electric Dryer
Dryers Logo
70 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
