Question about Nikon D70s Digital Camera
Nikon D70 will not power on after the lens was changed~
We changed the lens on out D70 Camera, and when we went to turn the power on nothing happened. Blank screen, no error messages. We took the battery out and charged it, but the same thing happened.
Any ideas?
Thanks!
  • Gary Miller
    Gary Miller May 11, 2010
    Is there any indication of power ? Like the " -E- " in brackets on the top LCD - or any display ? Have you tried taking the second lens off ?
    Novelist:
  • 121 Answers
EDAWinc,
Is this a new or different style lens? You may not have it all the way on and aligned - try removing it again. Just remember to always turn off the camera before removing the lens or the SD card. Malfunctions are sure to follow if that happens. Try resetting the camera by holding down the two buttons on the top with the green dots for longer than 2 seconds (that works with the D80) The camera will not come on if the lens is not "on".
randy320sgi
Posted on Jan 09, 2009
I am trying out a Nikon D70 and it is used. Don't have manual. Everything is automatic. When I hit the shutter button, nothing happens. On the top of camera housing, there is a letter F// that blinks,...
Fee blinks--lens aperture not set to minimum (largest f number)
F-- blinks--no lens or non-CPU lens attached. Use a DX nikkor lens or place camera in manual mode
Apr 25, 2011 | Nikon Cameras
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
May 28, 2009 | Nikon D70s Digital Camera
Are you getting any power from it? How about an error message?
Try blowing some compressed air into the battery chamber. There might be some debri or dust in there. Try replacing the battery to see if that solves it. (Someone you know must own a D70).
Apr 20, 2009 | Nikon D70s Digital Camera
Nikon D70 lens won't let me shoot
Remove the lens being careful not to get dirt/dust in the camera(very important).
Clean the metal contacts around the lens and on the camera where the lens and camera meet. Your error sounds like a lens communication error.
Again!!! Do Not Get dust/dirt/moisture/ anything in the camera.
Apr 03, 2009 | Nikon D70s Digital Camera with 18-200mm...
When I changed lenses my d70 went dead
I had something very similar happen to me.
I now know what I did wrong.
I was using an older type lens that did not have electronic contacts.
I forgot to turn the camera off before I removed the lens and I believe this may have short-circuited the camera electronics.
I have to get the camera repaired at a cost of about £90 (sterling).
Jan 09, 2009 | Nikon D70s Digital Camera
CAMERA WILL NOT SWITCH ON NIKON D70S
http://nikonsro.com/email_images/nikonusa/service_advisory/d70.html
Is this your problem? If so, Nikon will repair it for free, even if it's out of warantee. :)
P.S. Please stop "shouting!" (Turn off caps lock!)
May 31, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D70 problem
Noe at all except to contact Nikon for advice you may have damaged lens or camera
Sep 04, 2007 | Nikon D70s Digital Camera
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
D70 stuck
Make sure your memory card is OK. Take it out, put it back in or try another card. Be sure battery is charged. Should not see low battery sign in viewfinder or in top panel. Try a reset. There is a problem sort of related to what you describe where a firmware update may cure it. D70 Firmware Update 1.0.1 / 1.0.2 - Windows. One of the problems this firmware fixes is :"When images were captured in Continuous mode at an Image size setting of M and an Image quality setting of FINE, the memory card access lamp sometimes glowed continuously and the camera could not be turned off with the power switch. This problem has been corrected." This bit of advice comes from another Web forum, not my own discovery. Maybe this happened and ran down your battery, unbeknownst to you. Turn the camera off and power it from an electrical outlet. Update the firmware per instructions on the Nikon site. If this does not work or if your firmware is updated, call Nikon for further advice. You may need to have it serviced. This blinking light problem has been mentioned on PN and another forum. Nikon may be familiar with it already.
Sep 14, 2005 | Nikon D70 Digital Camera
Nikon D70s Digital Camera Logo
369 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
