Question about JVC RX-D302 7.1 Channels Receiver
JVC RX-D302 ON SOUND ON WIRELESS USB
Jvc rx-302 receiver,acording to manual, wireless usb's input mode should be digital auto with no provision for changing.this one says analog.and cannot be changed with digital/analog button on remote.is the unit bad? is there a factory reset? everything else (both digital and analog componants work fine) thanks in advance for any help
  • rynosaur74 Jan 31, 2009
    I have exactly the same problem. The PC detect the receiver but no sound can be player anymore :(
SOURCE: JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Posted on Jan 14, 2008
maklean
  • 1665 Answers
SOURCE: NEED REMOTE CONTROL CODES FOR RCA RCU1010 REMOTE TO CONTROL A JVC RX-D205S
Try this
Code 188 for JVC SAT
http://remotefinder.rca.com/
Posted on Jan 20, 2008
SOURCE: JVC RX 555 display not
The fuse lamps inside the unit have burned out. If you crack the case and replace the two 150mw 12v fuse lamps, you'll have a display again (assuming the protective diodes haven't fried).
Posted on Jul 23, 2008
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
ctau
  • 372 Answers
SOURCE: I need owners manuel JVC RX-5030v
The manual is now available to download the manual from this link
Posted on Mar 19, 2009
Have a JVC RX-9010V receiver and get no sound on FM , tv, etc.
no my antenna is a good one i tried with mp player too?? Is this a way to reset it to factory?
Nov 14, 2013 | JVC RX-9010V Receiver
Jvc RX 8020 receiver won't play when in DSP or Surround modes no sound at all, can only get sound in analog direct. Owned for 6 yrs. first problem ever!
I'd suspect one of the controls that would be overriden by analog direct is unknowingly activated. LOOK at the front panel and interpret every indicator for how it could cause silence. Refer to the manual for those you don't understand.
Any Tape Monitor activation would disable digital sources completely.
See page 14 for how Line Direct affects DSP modes.
Jun 27, 2011 | JVC RX-8020V Receiver
Hi, I have a brand new blu ray player, have set it to bitstream, and am attempting to use an optical audio cable, which does not work. The coax analog works fine but cannot get sound. I see in manual...
Instructions from manual
This receiver is equipped with two DIGITAL IN terminals-one digital coaxial terminal and one digital optical terminal.
You can connect any component to one of the digital terminals using a digital coaxial cable (not supplied) or digital optical cable (not supplied).
IMPORTANT:
• When connecting a video component using the digital terminal, you also need to connect it to the video jack on the rear. Without connecting it to the video jack, you cannot view the playback picture.
• After connecting the components using the DIGITAL IN terminals, correctly set the following if necessary:
- Set the digital input (DIGITAL IN) terminal setting correctly. For details, see "Selecting the Digital Input Terminals-DIGITAL IN" on page 16.
- Select the digital input mode correctly. For details, see "Selecting the Analog or Digital Input Mode" on page 17
The rest can be found on the link below. NOTE the page numbers referrer to the manual pages NOT the pages numbers on the site.
JVC RX 5032VSL Instructions Manual Selecting The Analog Or Digital Input...
Nov 10, 2017 | JVC RX-6030V Receiver
I tried restoring the sound by pressing Muting on master volume. Auto Muting still appears on the display and I can't restore the sound.
"Auto Muting" is for FM reception only and means it will mute the FM audio unless the signal is strong enough to provide decent audio.
Re-evaluate your symptom and corrective actions for relevancy.
Manual / Troubleshooting Page 31:
http://www.retrevo.com/support/JVC-RX-6000VBKJ-Receivers-manual/id/315bh050/t/2/
Dec 27, 2010 | JVC RX-6000V Receiver
Jvc rx-5020v dolby digital problem
Also...If your BluRay player only has a optical output for audio you will need to swap the inputs on the JVC rx-5020v. Press the "settings" button repeatedly until "digital in" appears on the display. Now use the "adjust" up and down buttons until DVD is selected as option 2. It will look like something like: 1CD2DVD Note: this may bugger any other previous setup you have.
Feb 02, 2008 | JVC RX-5020VBK Receiver
USB Wireless transmitter
the wireless transmitter use the same frequency as your wireless network and there should b a conflict. there is a way to change the frequency on the usb transmitter. once you do that, you should be ok.
Jan 02, 2008 | JVC RX-D301S Receiver
Getting no audio to game systems, pc connect won't connect
I also had the same problem when using my optical output for DBS and DIGITAL DVR/DVD.. you need to change the setting for this by on the remote changing to either analouge..rca sound input or Digital...for Optical input. The same problem cuaght me oput for a long time as well. The button is when you slide down the remote cover and the button is called analoug /digital
Dec 30, 2007 | JVC RX-D301S Receiver
JVC RX-D302 7.1 Channels Receiver Logo
146 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
