Question about Samsung SCH-u340 Cellular Phone
White screen my front sceen is working and everything and my phone rings and stuff but when i open it up the screen is all whit i took the bayyery out and nothing is working
  • Anonymous Oct 28, 2008
    I have the exact same problem, and have no idea what is wrong with it either......hopefully someone will give us an answer.
  • 24 Answers
Your phones problem is the FLEX CABLE connecting the phones LCD to the board.
Go to the nearest service center in your place for them to fix it
Posted on Nov 08, 2008
So what happened was that i was walking outside and my phone came out of my sweeter on to the floorbut the ground wasnt dirty or wet. (the phone had already fell once that day) i picked it up and looked at...
take it apart and check your flex cable connection, see you tube video for taking your phone apart, easy fix if you have a small screwdriver. Takes about 15 minutes.
Nov 07, 2010 | LG VX5500 Cell Phone
My phones screen goes white
WHITS SCREEN DISPLAY.
hi,
there are two kinds of white screen in n70 ,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your N70 im sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to a nokia care center to fix you problem...
i hope ,i will help you ,thanks for trusting fixya...
Jun 17, 2010 | Kyocera wild card Cellular Phone
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
My KG290 was dropped and the sceen stoped working.
YA U CAN CAHNGE D SCREEN.ITS EASY....GO TO A SERVICE CENTRE
Oct 31, 2009 | LG KG290 Cellular Phone
My Sony Ericsson W580 just shows a white sceen an i cant go to anything else
More than likely you will need to replace the display screen but before you do take the screen out and reseat the LCD connector. This will sometimes fix a white screen.
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
Mar 22, 2009 | Sony Ericsson w580i Cellular Phone
Display not lighting up
i think whoever squeezed ur phone,squeezed WAY to hard and took the color cartirge out.try gettinbg a new 1.i have NO idea about the volume...
Jul 18, 2008 | Motorola Mobility V31 RAZR GSM Cell Phone,...
Nokia N70 white screen
jus use a hair dryer for a FEW min ONLY...prob solved
Jul 17, 2008 | Nokia N70 Cellular Phone
Broken screen
I have the same problem......I NEED HELP!
Jun 09, 2008 | Nokia 5300 Grey Cellular Phone
W810i
DO not turn it on, youl fry the chips
dismantle it if you have the tool, put everything in the freezer (battery, keyboard) try not put the screen in
take it out once frozen and leave it in Sunlight.
Oct 27, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Samsung SCH-u340 Cellular Phone Logo
130 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
