Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Setup disc for maxtor 3200 200GB was missing in package
Can you send me a startup disc for this drive?
You don't need a disk, just plug it in.
Posted on Oct 12, 2008
Where does the driver disc for my Sylvania Turntable Model STT008USB go?
The turntable itself does not require a driver. The PC should identify it when you connect it to the USB port. The startup disc contains the Audacity program that you need to use to convert the analog audio from the turntable to digital audio format. Install the Setup disc in your PC's disc drive and if AUTORUN doesn't automatically start the install, explore the disc and click on the SETUP.EXE file to install Audacity. If you are trying to do this using a netbook or other device that does not have an optical disc drive installed, you will either have to get and external optical drive or, on another device that HAS an optical disc, copy the files from the startup disc to a USB stick and run them from there.
Nov 03, 2016 | Sylvania Televison & Video
Where does the start up disc for the Sylvania Turntable Model STT008USB go?
Windows\systems32\config\system file is missing or corrupt
You can order a new set of disks from the manufacturer or pull out the had drive and plug it into another PC or buy an external hard drive dock . Newegg has them for around $20
Mar 09, 2014 | Insignia Computers & Internet
Bootmgr missing error on startup
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Oct 09, 2012 | Dell Studio 1737 Laptop
Hi. I configured my Maxtor Shared Storage II with my home PC. Now the PC is dead. I tried to connect the other my PC (with Windows 7 as operating system) to Maxtor Shared Storage II, but the PC cannot see...
try and assign the drive a drive letter by right clicking on my computer and choose manage.
go to disk management
look for the maxtor hard drive.
if you see it listed there below you should be able to right click on it and assign a drive letter.
if you dont see it then it doesn't detect the hard drive. please check your hard drive connections and try again.
Mar 06, 2011 | Maxtor Shared Storage II (S01R320) Hard...
I have re loaded maxtor onto anothe computer using the start up disc but when executing a window appears asking for driver information. what do i need to do ?
it is asking for the drivers that it needs to "talk" toyour drive. a driver is a small software program that makes a hrd ware device work. when you bout the drive there should have beena disc with drivers on it. perhaps the startup disc even. unplug the drive from the computer and install the drivers then re plug it in. it should work. if you do not have the drivers for it you can get them from www.maxtor.com/support
but most likely the disc you have has them on it. the trouble you have is that you MUST unplug the drive and install the drivers FIRST. othwise you will get an error asking for the drivers.
so just unplug it and put the disc in you drive and look for "install drivers" option when the cd starts up.
Jun 27, 2010 | Maxtor (A01E250) 250 GB Hard Drive
I have maxtor 3200 500 gb need drivers
Hard drives do not require drivers.
Make sure your BIOS can SEE the drive and identifies it correctly.
Usually hitting the Delete key or F2 Key at system startup.
If the operating system starts up you have missed the bios screen.
Oct 18, 2009 | Maxtor Hard Drive
Maxtor One Touch II - installation Software
I have a disk that worked for me and I am running windows xp. I also have the website address that is supposed to have the 98 drivers which could work perhaps. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Maxtor_OneTouch_Drive_USB/Win98SE_Driver&vgnextoid=b07d8b9c4a8ff010VgnVCM100000dd04090aRCRD
Guess you could try them first and if that doesnt work I could perhaps make a backup of the disk/package/mail/ worth anything?
Feb 05, 2009 | Maxtor One Touch II E01H300 (EO1H300) 300...
No setup disc in package
Most external drives to not need installation discs. They are driven via USB, which Windows has built-in support for.
Any software that comes with an external drive is usually S.M.A.R.T. drive software or other "disk utilities", neither of which you have to have in order to use the drive.
Plug it in and go :)
Let me know if you need any further help, and be sure to rate users who offer their time & expertise for free :)
Sep 29, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
55 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
