Question about Samsung RS2630WW Side by Side Refrigerator
Icemaker won't fill with water
We've just moved. Pro movers handled packing, loading, moving, and unloading. Refrigerator, in-door water, and icemaker worked perfectly before move. After the move, I hooked up the icemaker to the water supply built in behind the refrigerator. Checked the water flow, there's plenty through the tubing to the refrigerator. Water-in-the-door feature works, but flows less than it did at other location, fills glass probably half as quickly as previously.
Icemake won't fill at all. Ref-side temp is 37-39 degF. Freezer-side temp is 0-5 degF. Built-in water filter indicator shows the filter is good, but will gladly replace if necessary. Checked the icemaker connection on top of the refrigerator, and the line is dry. No water visible in line.
No kinks anywhere in copper tubing from wall to ref, none visible in plastic lines under ref to fill valve and going toward door.
Is there an actuator or switch that needs to be activated? What have I missed?
Thanks very much,
Lynn B.
  • LynnB5206 Sep 30, 2008
    Okay, it's fixed. I found a similar problem and solution here, and my problem was exactly the same. Thawed the fill line (very gently) with a heat gun, cycled the icemaker via the reset button, and the ice blockage came out. I cycled it several more times to clear the line completely, then buttoned it all back up. I should have ice by morning.
    Thanks very much for keeping questions and answers archived!
    Thanks again,
    Lynn B.
  • Anonymous Mar 19, 2014
    The water is on - there seems to be water getting to the filter inside - but not to the door or icemaker...
    Guru:
  • 93 Answers
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Thanks
Posted on Jan 04, 2009
Which is the best mover and packer service if I have to shift to a new home?
The best Packers and Movers I would suggest you is Findmovers.in. This is the best portal you can check the all packers and movers company list across India Also see the company rates, reviews and prices. The best part is the friendly, uniformed and professional certified employees move packages, loading, transporting, unloading, unpacking and placing your belongings with care and perfection. More Information Visit This Website:- www.Findmovers.in
Nov 23, 2016 | Miscellaneous
What are some cheap options for long distance moves?
U-Haul offers a service where you can pack everything up and helpers load the truck and when you get to your new home another set of helpers will meet you there to unload. It depends on how you set your budget as well. You may want to check out companies like pods where you load the storage trailer and a truck picks it up and drives it to your destination. ABF is a freight hauling company which offers a 26 ft. trailer that you load with a liftgate and that too will be brought to your new home. Shop around theres a lot of ways to save and have it done hassle free.
Sep 07, 2012 | American Woodcrafters Furniture
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
GE side by side GSL25JFXLLB won't stop making ice. I had this refrigerator for 23 months. The builder installed it in my home. I had a -one-year warranty, where the door had to be replaced due to...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Oct 03, 2011 | Refrigerators
I recently moved. After re-connecting my LG Fridge I noticed that you can hear the water run for several seconds before it starts to fill the glass with water. What could be the cause of this?
Usually a small leak in the water line from water valve to the water filter.
I have seen when moving a ref the movers catch the plastic water line on the back of the box on the home door to the outside and damage it.
Pull out the Ref. and inspect the tubing.
Be sure to protect your floor.
Jan 06, 2010 | LG LRSC21934 Side by Side Refrigerator
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore fridge icemaker doesn't work after move
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Oct 11, 2008 | GE Profile PSI23NCR Side by Side...
Samsung RS2630WW Side by Side Refrigerator Logo
264 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
