Question about EliteGroup GeForce 6100SM-M Motherboard
4to8pin atx i bought an ayx power suppy with a 4 pin 12v suppy i know you can get a 4 to8 adapter but i could make one myseif if i had a diagram of the 8pin specs for each slot ie;+12,-12,common
  • 155 Answers
You don't need an adapter from 4 to 6 pin, the mother board needs a 4 pin atx connector.
You can download the complete manual from here:
And you can see the pins layout.
Let me know if you need more help
Posted on Sep 30, 2008
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
My motherboard takes this: 1 x 8-pin ATX 12V power connector My PSU (power supply) only has the 4-pin 12V power connector. Can someone please point me to a product that will convert the 4-pin to an...
Hi Andrew.
Just had a look arouund on Amazon, and if you do a search for
EPS 8-Pin Power to ATX 4-Pin Cable
There are a couple that turn up.
Hope this helps.
Apr 16, 2011 | Computers & Internet
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
Can you connect the 4pin power supply to the 8pin on board 12v
Yes, you can connect the 4 pin power supply to the 8 pin with little trouble but, you should not try any advanced features like overclocking or crossfire. If you would like to do those things I suggest getting a 4 to 8 pin adapter (very cheap usually less than $5) at most local computer stores.
Oct 10, 2010 | Gigabyte GA880GMUD2H AM3 AMD 880G HDMI...
Do I plug in BOTH the 20+4 ATX power connector AND the 8 pin 12V connector on a gigbyte MB (MA790GPT-UD3h)?
You only need to plug the 20+4 ATX power connector and how about the 8 pin 12V connector? Well that is use only for legacy type of motherboard that use to require it.
Hope it helps..
Thanks for reaching Fixya
Apr 03, 2010 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Motherboard power problem due to atx 12v cable
I tried different power supply but its still not powering up. But when i remove the 4 pin 12V cable from power supply the cpu fan is rolling, it means that the power supply is working but when i tried to connect the 4 pin then the cpu fan stop just a second and never rolled on. The main problem is the 4 pin, the model is Asus P5P800-VM. I tried to reset the cmos and replaced the battery but it wont work out. Please help me!!!
Jun 09, 2009 | ASUS P5P800-VM Motherboard
Some motherboard/cpu setups require an additional 4-pin connector for additional power on the motherboard. The motherboard will require either a 20-pin or a 24-pin power connector (main power), and might need the additional 4 pin as well. If the motherboard will accept the additional 4-pin, then connect it!
Sep 04, 2008 | Gateway GT4022 PC Desktop
EliteGroup GeForce 6100SM-M Motherboard Logo
54 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
