Question about Pelonis WM-HO202C Oil Filled Radiator Heater
Electric oil filled model #ho-301
Where is the pilot light
  • 3 Answers
There is no pilot light. It is an electronic unit.
Posted on Feb 23, 2009
Need KSD-301-V thermo switch for a Pelonis HO-O218 oil filled heater
Amazon has lots of these thermostats available from 3 to 5 dollars. This is the most common thermostatic switch failure for the Pelonis heater . Go to Amazon and type in KSD 301 in the search area. The temperature rating of the sensor is approximately 305 degrees
Jan 31, 2015 | Pelonis Heating & Cooling
Error code 005-301
Please try the following
- Lift the cover to expose the flat bed scanner glass.
- Under the cover, there is a long white bar with two white tabs perpendicular to the white bar.
- One of the tabs could be retracted. Pull on the tab until it is fully extended.
Error "Cover Open 005-301 Close ADF Cover" and solution is Close the cover of the ADF
Jul 23, 2014 | Dell 3115CN
Pelonis oiled filled heater ho-0218 won't heat up
burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm. no you do not need to add oil, if the unit leaks throw it out.
Mar 24, 2014 | Pelonis Heating & Cooling
Our staff cleaned the fryer last night and left the pilot on without filling the oil. . The fryer was with no oil and pilot on overnight. Will it lead to problems or we have to take corrective action.
If the main burners didn't light there shouldn't be a problem. If the main burners came on there could be some damage to the tank but there is no corrective action that can be taken. If damage was done it will usually leak cooking oil when filled. Was the gas valve turned to "pilot" or "on"?
Dec 12, 2010 | Pitco Frialator SG14 Deep Fryer
I need a switch for my heater,how do i order the on and off switch for my oil heater pelonis-model#Ho-157c0109
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
Feb 09, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
I need to know how to lite the pilot on my frymaster fryer
fry099_16_4.gifMake sure the thermostat is turned off. Units burners will light as soon a pilot in it is on. fry099_16_5.gif 3-2 Lighting the Pilot and Burner Figure 1 Figure 2 3. Push the knob in and light the pilot. Continue to hold the knob in for about 60 seconds after the flame appears on the pilot. Release the knob. The pilot should remain lit.
I suggest that you boil it out before using. This cleans the pot of any contaminants here is how to do this.
Boiling Out the frypot To ensure that the frypot is free of any contamination resulting from its manufacture, shipping, and handling during installation, the frypot must be boiled out before first use. Frymaster recommends boiling out the frypot each time the oil or shortening is changed. 1. Before lighting the burner, close the frypot drain valve and fill the frypot with a mixture of cold water and boil-out solution or detergent. Fill to the lower oil-level line. 2. Light the fryer in accordance with the lighting instructions in Section 3.1. 3. Simmer the solution for one hour.
I would attempt to paste the complete owners manual but it's just way to large. I do warranty for Frymaster is how I have access to it. Good luck
Oct 17, 2009 | Frymaster Dean GF14 Deep Fryer
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
Model ho-0218 at a given time can the mineral oil be refilled
hi , i have to ask why would you want to refill it , if the heater is leaking its rarely econamical to fix the leak and repair it , most of the oil heaters ive worked on were filled with vegetable oil .
Oct 15, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Pelonis WM-HO202C Oil Filled Radiator Heater Logo
470 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
