TV will not turn on. Pressing the power button produces an audible click from the rear of the unit, but no other indication of power.
  • 4,234 Answers
The click you hear is the power relay engaging. If you get no further indication of any cactivity or you jsut hear a second click, there is an internal problem and the protection circuits are shutting down the set. Was there any symptoms prior to the set being dead? If not, the most likely cause is either a shorted horizontal output transistor or convergence ICs (assuming a CRT based set). Usually DLP or LCD based projection sets have indicators on the front that will flash when there is a problem with the lamps. If you can post the make and model, I can provide a more detailed explanation and possible fixes.
Thanks,
Dan
Posted on Sep 30, 2008
    Sergeant:
    Champion:
  • 223 Answers
It sounds like a faulty component on the power supply. Capacitors can cause that click you are describing so if you start your check there you might find the problem pretty quickly. Also check resistors near the faulty cap as these could have been taken out. If you are not able to check this yourself entrust a competant technician. Good luck.
Posted on Sep 29, 2008
  • Paul Sep 30, 2008
    Lol Dan please give a rating for the comment I provided matter of pride dont you know :-)
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
Cat stepped on remote TV went black have sound but no picture i have tried every menu option?
Try doing this:
9.1.2. Exit
This is straight out of the service manual.
Regards,
Joseph Van Buren
Aug 01, 2014 | Panasonic TH-42PX75U 42 in. Plasma HDTV
Panasonic tv
If the front panel indicator is on and pressing the power button does not produce results, there could be a blown fuse internally or something wrong with the power supply
Jan 10, 2013 | Panasonic TC-P42X5 42" 720p Plasma HDTV...
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
Can I turn the beeper off on the end of the washcycle on the DDY062 Hoover dishwasher. I want to put it on timer delay and dont want to be woken in the middle of the night.
These are the instructions taken directly from the DDY062 manual:
Alarm mute for the PROGRAMME END
The alarm for the programme end may be muted as follows:
IMPORTANT The dishwasher must be ALWAYS off before start this procedure.
1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound).
2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound).
3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on).
4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off).
5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting.
To turn the alarm on again, follow the same procedure.
Jun 21, 2012 | Hoover Dishwashers
Okay, so my Panasonic PT-43LC14 went black in mid show last night. The bulb is approximately 18 months old. The LED indicators upon Power On are; Power LED blinks green for approximately 70 seconds; Then...
Check the bulb again and look at the root of where the main stem comes out inside and be sure you don't see any bubble like appearence around the stem at the bottom there. If you do see this then the bulb is bad. Otherwise try this: Hold volume down on front of unit and pip on remote for about 5 seconds. Message will come on screen that timer has been reset to zero. This sets the lamp timer to 0
May 17, 2011 | Panasonic PT-43LC14 43" Rear Projection...
Vizio takes a few clicks of the power button to turn on.
This is an indication of leaky filter electrolytic capacitor on the power supply section.
A dried up main filter capacitor or other filter capacitor in the power supply will produced an out-of-regulation condition until it warms up.The symptom will get worst if not isolated.
I've advice you to look for a qualified technician to replaced the said parts.But first check if your unit is under warranty then avail it because the manufacturer of your unit will fix it for free or a little charge only.
Thanks for using fixya.
Jan 26, 2011 | Vizio 42 in. LCD TV
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
