Question about Hoover U5491-900 Bagged Upright Vacuum
Vacuum stopped working suddenly after working fine.
I was vacuuming in one room and as I proceeded to the next the vacuum would not turn on. I've tried in multiple outlets, I let the vacuum cool and have changed the bag. I think I need to troubleshoot the On/Off switch, Cord, Motor and Thermal connector to determine the issue. However, I don't know how to break down the vacuum to check or what to look for to diagnose each. Can anyone help?
SOURCE: off/on switch does not work
It really worked,
Thanks for this uggestion!!
Posted on Nov 05, 2007
reddevil6
  • 1673 Answers
SOURCE: Hoover windtunnel will NOT turn on
You have to remove the motor cover, There I believe 5 screw, take off the light lens and remove the screw holding the light. It should then pull off. You say you have power to the Vac, but do you have power to the motor. There also is a thermo by the motor, sometimes they open up, then the motor won't run.
Posted on Jan 06, 2008
SOURCE: Vacuum doesn't work when main attachment is on....
S3765-040, power head would not run when the handle was elevated. Problem was with wiring from connecter plug on power head swivel into the power head itself, because of the design the wire tends to develop a short. Test it by turning on the vacuum, elevate the handle, then when it stops running move the visible part of the wiring with you foot/hand. If it starts/stops then you have a short. Replacement part was about $10.
Posted on May 25, 2008
SOURCE: No power to Hoover Wind Tunnel Vacuum
the problem is likely the switch a shot of wd40 should fixed it
Posted on Oct 11, 2008
SOURCE: replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Posted on Jan 03, 2009
Won't turn on stop running in the middle of room.
Mine did the same thing. The electrical cord is loose where it plugs into the machine. When you pull the vacuum into the room it puts just enough strain on the cord to break the electrical connection. Push the plug on the cord firmly into the vacuum.
Sep 08, 2013 | Eureka 3276AZ Pet Lover Bagless Upright...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Stopped sucking up on carpet
Dear Sir:
1) Open the dust cup 2) remove the hoses and clean 3)OPENING the vacuum for some blockages too. and proceed according.
God bless you
May 24, 2012 | Euro-Pro NV31 Infinity Vacuum
Once vacuum is turned on and switched to a certain carpet level, the red light begins to flash and the brush stops spinning. How do we fix this?
The brushbar is designed to stop rotating if you've set it at a level too low for the pile of the carpet you're trying to clean. The indicator light will flash to warn you of this. Using the cleaner with the brushbar raised to the next level on the selector pad should prevent this issue from occurring.
If you have any further concerns about your vacuum, please get in touch with us directly on 1866MYDYSON. One of our experts will be happy to provide the assistance you need.
Kind regards,
Jack
Dyson Online Customer Support
Sep 24, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
My vacuum worked just fine... i went in another room to use it and now it won't turn on no matter what outlet i use!
If it works in the other room's outlets, I would think that it might be tripping the circuit breaker for the room it isn't working in. Check your circuit breakers.
Dec 07, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
My Oreck vacuum cleane won't turn on
I have an Oreck vacuum. My son used it just earlier today and it worked just fine, then just a little while ago a tried to turn it on to vacuum our bedroom and suddenly it won't turn on! I tried plugging it into other outlets but it was no use. My husband takes a look at it and first thinks that the switch is out in it. He takes the handle apart and quickly realizes that it is not the switch that is causing the problem. Then he took the base of the vacuum apart, removes the spin brush part and cleans it off, puts it back together, and suddenly it works! He said that when those brushes get real dirty the motor gets clogged, then it just won't turn on. I'm just happy I married someone who can figure these things out, because even if I knew the problem I'm still no good with a screwdriver, taking things apart and putting them back together again. Hope this works for your Oreck too and it's running again for you soon.
Jun 18, 2010 | Oreck XL2200 Bagged Upright Vacuum
I have aeureka 450, it stops suddenly when I vacuum? HELP
the motor is probably overheating. you will probably have to replace the motor.
Apr 04, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
Loud noise??
I have the exact same problem. I've taken the thing apart and cannot figure out what is causing the noise. It's not the belt and it doesn't seem to be coming from the engine. It sounds like the spinning brush is hitting something, but it's not, that I can see.
Jul 12, 2008 | Bissell 6590 CleanView Bagless Upright...
Hoover U5491-900 Bagged Upright Vacuum Logo
37 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
