Question about Dynex DX-E401 Router
MTU I need help with my router i have xbox live and it says my MTU is not high enough how do i change that on the router??????????????
  • 4,338 Answers
What router is it?
Posted on Sep 29, 2008
We need to change our MTU setting to 1364 or higher. We have a XBOX live which requires this setting. How do we do this?
Go to the following link I will provide and your problems will be solved.
http://support.microsoft.com/kb/826159
Jun 04, 2011 | D-Link Wireless N 150 Home Router 4Port...
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
Hey i have a thomson TG782T and i am trying to connect an xbox 360 elite to xbox live through an ethernet cable and i am having the mtu error come up. i already have an xbox 360 slim connected which works...
Maximum transmission unit is 1500, but for the Xbox 360 it "must" be set within the range 1364 - 1492
Since there's no MTU settings for the TG782T. your only choice is to replace it with routers like Linksys, Belkin, Netgear.
Jan 05, 2011 | Microsoft Xbox 360 Console
MTU settings not high enough for XBL ??????
The MTU or maximum transfer unit is configurable at the
modem that is bringing the internet service, in your case the Thomson tg782t modem, do not attempt to change the registry
Jul 09, 2010 | Microsoft Xbox 360 Console
How to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
http://help.expedient.com/broadband/mtu.shtml
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Mtu settings
Two things needs to be cleared:
1) Which connection did you talking about LAN/WAN?
2) Xbox live may not be up yet, can you verify it?
Most home gateway routers can only change WAM MTU for certain connection type (PPPOE), and cannot set MTU for LAN and other WAN connection.
To change MTU for PPPOE, going to WAN connection setting, and you will see the MTU options box. But do not change it unless your ISP told you to do so.
So make sure Xbox live is online -- I am no Xbox fun so I have no idea how it works, but just guess from your message.
Jun 19, 2009 | Belkin (F5D7633UK4A) Wireless Router
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Mtu
If you have your Xbox connected through a router, most routers, on their control panel (192.168.1.100 for example) give you the option of setting an MTU, or leaving it to default. This option is normally found on the setup page of your routers control panel.
MTU stands for maximum transmission unit, basically a speed thing.
If you can set it, change it to something above 1500 depending on how fast your internet connection is, but I am fairly certain that 1500 is the minimum that you would want to have set for xbox live.
Another way to do it is, if your router has this option, set the MTU to Automatic. That way your router (should) be able to do all of that dynamically as the need arises.
I hope this helps to solve your problem, good luck!
May 16, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
69 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
