Question about Dryers
Can I run a 12 foot flexy duct from a tumble dryer up into the loft and vent out through the roof?
  • 943 Answers
Hi thanks for the question . You can , but only alluminium That wont kink . So its ok thanks the appliance doc
Posted on Sep 29, 2008
Dryer "check vent" light goes on
if air coming out back is strong it might be a bad sensor somewhere
Feb 11, 2015 | Dryers
The heat goes on temporarily and then shuts off
The most common problem is a clogged vent.
To do this, unplug your dryer and move the dryer out enough so you can get to the dryer duct easily. Most dryer ducting is flexible like a big slinky with a vinyl(older style no longer used) or metal type covering. There are some that are rigid as well.
Remove the duct from the dryer and where it attaches to the wall. Use a shop vac or house vac with attachments and insert through the wall and vacuum as much as you can. I use a shop vac since it has the blowing capability and I can check if air is coming out of the dryer vent located outside after I vacuumed it out. It is good to get confirmation that air is coming out of the vent. Check the dryer where the duct was attached and vacuum anything that is in there. Put everything back in reverse order and give it a whirl.
There are some homes,condos,and apts the have the hidden ducting go up the wall and through the roof. If this is the case, you will need to go on top of the roof and find the vent pipe. This pipe will have some sort of cap on it to let the hot air out but keep other elements out. Since you mentioned the heat goes on for a bit, have someone go on the roof (use caution) and have someone else turn on the dryer. The person on the roof can check the vent pipes with his hand for heat.
Nov 16, 2010 | Whirlpool Dryers
I have a maytag performa electric dryer model #pye2300ayw, rev 10 -- sometimes I need to run the dryer 3-4 times to get a load dried. I checked the outside vent and there is alot of hot air coming out, the...
We had this same problem recently. Don't know if your problem is the same, but I am sure it could be.
While we did have hot air coming from the outside vent, it was still a restricted vent duct that was our problem. I went to Lowes and bought a dryer vent cleaning kit for about $40 (I figured I needed to do this anyway, as I'd been hearing about how many housefires are caused by the heat buildup from poorly breathing vent tubes/ducts), and cleaned the whole length of the duct (and replaced the plastic flexi-tube inside with a metal one).
I had thought I had good air-flow before doing this, but oh my gosh, what a difference this made! And I couldn't believe the pile of nasty, damp lint that came out!!
Anyway, our dryer immediately went from requiring 2-3 cycles to dry a load of clothes, to doing a great job the first time through! Perhaps the same solution would help you. I hope so!
May 29, 2010 | Maytag Dryers
Tumble dryer overheating
This will occur if the running thermostat is stuck closed. This thermostat will be located inside the dryer on the vent duct or blower housing. it must be replaced in order to restore normal functions.
Also, improper ventilation can cause this as well. have the entire vent assembly cleaned asap.
Aug 08, 2009 | Dryers
Electric Dryer takes too long to dry clothes. Hose/vent is not crimped or locked. How do I clean out the vent built into the wall and ends at my roof top?
Here's a trick I used on my laundromats with vertical exhaust vents on the dryers..
When the dryers began drying too slow, taking too much time, giving out too many refunds...
I resorted to climbing on the roof with a webster duster... it looks like a chimney sweep brush on a telescoping pole.
I turned the dryers on and while they were running, ran the webster duster down the vent pipe.. It cleaned out the duct very well! I got "linted" but it worked!
Remember that the vent run should not be too long. If it gets too long, it will not stay clean and it will take too long to dry as well. if this is a recurring condition, you may want to consider a reroute of the duct.
Also, the exhaust end should be free flowing... no screen. A self-closing flap is okay, but no screen..it will simply clog up the works...
Try the webster... they sell them at the local grocery store... they come with their own extension pole too!
Let me know how it goes!
k
May 29, 2009 | Oregon Scientific Electric PTO Clutch for...
Not drying clothes
If the unit is heating properly which it should pull around 25 amps when heating , and the unit is tumbling it is 100% an exhaust issue , either a kinked duct behind the unit , a ball of lint stuck in the duct , lint build up outside in vent , or water in under ground duct. If you find the clog it will be FIXED!
Let me know if you have any other questions.
Phil
Apr 14, 2009 | Whirlpool WED6200S Electric Dryer
Dryer wont dry but heats and tumbles. takes 3 cycles to dry
Have you checked the entire duct run. When dryer vents should feel like a hair dryer on high blowing outside
Feb 16, 2009 | Roper RES7646KQ Electric Dryer
Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Sep 27, 2008 | Hotpoint NVL333EY Electric Dryer
CLOTHES DRYER (ELECTRIC) HAS HEAT AND TUMBLES BUT CLOTHES ARE NOT GETTING DRY.
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER. RUN ONE LOAD OF LAUNDRY. IF THE LOAD DRIES O.K., THE EXHAUST DUCT IS RESTRICTED. CLEAN OUT THE DUCT WORK. IF IT IS FLEXIBLE MATERIAL, REPLACE WITH RIGID METAL DUCT WORK.
Apr 22, 2008 | Dryers
This complaint is most often caused by the dryer's vent being blocked with lint. Dryers need to be properly vented, otherwise the moisture in the air can't be properly carried away. Vents that go out the roof are particularly problematic-- the dryer may take far too long to dry clothes and the vent pipe may even drip water that can't be exhausted. Minimum size for a dryer's roof vent is 4 inches. If your dryer has chronically poor drying, if possible, have the vent moved to where it exits a house wall near the dryer. The vent should be made of 4-inch aluminum rigid duct and elbows or, where absolutely necessary, flexible metal (but not flexible thin foil). Do not use flexible plastic duct-- it restricts air flow and is combustible. The dryer should vent outside--never into a crawl space, wall, ceiling chimney, or other type of flue. The bottom of the exhaust hood should be located at least 12 inches above the ground. Here is what to do: 1) Check the lint trap and clean it. 2) Be sure the dryer isn't pushed so close to the wall that it pinches off the airflow through the vent's air duct hose. 3) Check the point where the air duct vents away from the house. Be sure plants, birds, or anything else hasn't blocked it. If the duct vents out the roof, it could easily be blocked with lint. 4) Disconnect the air duct hose from the back of the gas dryer and clean out built-up lint. Note: For safety, first turn off the gas to the dryer, then unplug the dryer; this means you will have to re-light the pilot light later if the dryer has one (read your owner?s manual for proper re-lighting techniques). 5) If necessary, clean out the ductwork from the dryer to the exterior wall where it vents; this may involve disconnecting sections. One trick that sometimes makes this job easier (but only if the dryer duct is fastened firmly at all connection points) is to blow lint and debris through the duct and out the exterior wall vent, using an electric leaf blower.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
