I have a goodman LD3755HD TV tonight we had a power cut while the tv was on . now the power is back I cannot get the tv to turn on. Tried fuse, batteries in remote, all the usual. is there a reset button I dont know about or has it blown something?
  • stewartg40 Sep 29, 2008
    Thanks for the help I will get someone in, at least I can sound like I know something about it
    Sergeant:
    Champion:
  • 223 Answers
It could have blown the internal glass fuse/s on the power supply otherwise its a component on the power supply board. Failing that it would have to be in fornt of me lol. Good luck.
Posted on Sep 29, 2008
Goodmans LD3755HD Picture Problems
Pls try using the TV with pure video signal only such as a DVD or even an old VCR. If the problem persist with the DVD, then yes it could be the video processor, if not than chances are it is the built-in tuner of the TV (most likely). Since the tuner block is a single assy, then it would be relatively easy to identify and replace. Often, it would look something like below.
If on the other hand, it is the video processor, then your best would be to get hold of a service manual or at the very least a schematic diagram with voltage readings if you are considering a do-it-yourself repair.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 23, 2008 | Goodmans W280NS Television
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
Goodmans HDMI. After power cut (which it is used
I just left the TV off and it must have reset itself. It did it twice. First time it was OK after half an hour. Second time it was nearer an hour.
Thanks
Jan 08, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Tv did not turn on
Look at the power supply to see if anyhting burnt, fuse, bad capacitors. I doubt that the power cord is bad, the same size fuse should be used as the original one.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 04, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Tv not turning on
You can try leaving the TV unplugged for 30 - 45 mintues so the TV discharge and reset itself.
If this doesn't work, the TV may have just a blown fuse inside that just needs replacing. Or, it's going to be a power supply board related problem.
Aug 07, 2009 | Panasonic TH-42PZ77U TV
I have an goodmans LD3755HD 18 months old and there is no power
yes its very much possible.you can also fix it.as you say that there is no power in the front pannel and no red light is comming up.its just the problem of fuse in the main board that needs to be replaced.it will cost you hardly under $1 for new fuse.replace it.
Mar 07, 2009 | Goodmans W280NS Television
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
for cms voodoo, change your power module.
for tomchik, check your input voltage for voltage drop or fluctuation, if any employ voltage stabilizer, then change your power module. make sure that there is enough ventilation around your tv.
for bananahead , go and change your backlight inverter
Jan 05, 2008 | Goodmans W280NS Television
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
