Question about HP Photosmart 8250 InkJet Printer
HP Photosmart 8250 won't pick up photo paper...
When I first bought this printer, it worked fine. Then all of a sudden, it wouldn't pick up regular photo paper in the tray. The tray would go in and the screen said that my pictures were printing, then a message ont the screen would say Out of Paper. Load paper then press OK. It seems like if I keep pressing OK everytime I get that message, eventually my pictures will print, but I have to keep trying about 25 times before they will. Also, once it starts printing pictures, it will usually have no trouble picking up paper. The setting is set on Photo Tray on the printer, and I use HP photo paper.
  • 3 more comments
  • jakesails Jan 02, 2009
    I have this EXACT same problem. It simply will not consistently pick up regular paper in the tray. The tray would go in and the screen said that my document was printing, then a message comes on the screen saying Out of
    every time I get that message, eventually my document will print, but I
    have to keep trying about 5 times before it actually picks up the paper. Very frustrating.
  • Anonymous Feb 26, 2009
    I have the same problem. It's very frustrating. :(
  • Anonymous Mar 07, 2009
    Same exact thing! Frustrating...
  • Anonymous Mar 09, 2009
    won't pick up paper! annoying,
    won't pick up paper
MUKHTAR
  • 2022 Answers
SOURCE: HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue. Step one: Reset the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Wait 30 seconds, and then plug the power cord into the back of the product.
  3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
Step two: Check the condition of the paper and reload it
  1. Lift the photo tray lid.
  2. Slide the paper width guide all the way to the left.
  3. Remove the paper from the tray.
  4. Replace any ripped, dusty, wrinkled, or bent paper.
  5. Make sure that the stack of paper contains only one type of paper.
  6. Tap the paper stack on a flat surface to align the edges.
  7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
  8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
  9. Lower the photo tray lid.
  10. Extend the paper catch.
  11. Try to print the job one more time.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step three: Choose the photo tray in the print driver settings
  1. Open the document to print.
  2. Click File , and then click Print . The Print window opens.
  3. Click Properties . The Properties window opens.
  4. Click Printing Shortcuts , and then click the shortcut you want to use.
  5. From the Paper source drop down list, click the paper source.
  6. From the Size is drop down list, click the paper size.
  7. From the Type is drop down list, click the paper type.
  8. Click OK , and then click OK again to print the document.
  • If the issue persists , try the following Workaround.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Sep 08, 2009
SOURCE: Unable to print to photo tray
FIXED BY ADJUSTING PAPER SIZE
Posted on Sep 21, 2009
SOURCE: I have a photosmart 8250 using iphoto, how do I
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Posted on Oct 22, 2009
SOURCE: Photos in Mac's iPhoto will
This is an older post, but it appeared to be unanswered. In iPhoto once a photo is selected, you hit "Print" at the bottom right. A preview screen with options comes up. Once the correct options there are chosen, you need to hit print again - but it does not print yet. Instead a second "Print" window opens. In the middle of this window there is an "iPhoto" button with arrow buttons on the right. The arrow buttons open a drop down menu. Choose "Paper/Paper Quality" from that menu, and it will give you a button for "Source." The arrow buttons on the right of the "Source" button allow you to choose "Photo Tray."
Once it's changed, you don't need to redo it each time you print an additional photo, since iPhoto reverts to "Last Used Settings." But as a shortcut for future sessions, you can save these settings using the "Preset" button located at the top of the second "Print" window (the window where the "iPhoto" button is located). I used "Photo Tray" in the description so it would be obvious, since I don't print pictures every day.
Posted on Feb 20, 2010
SOURCE: Hi...I have a problem with
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Posted on May 22, 2011
My HP Photosmart 3310 will not pick-up A4 glossy photo paper in the main tray. 6x4 works fine in the photo tray
Your printer might have opening area for clearing paper jams, also on that area there are some rounded parts that do actual picking-up of paper. Clean those parts with some non-agresive cleaning agent and try again.
Mar 06, 2011 | HP Photosmart 3310 Printer
The paper won't feed properly. Regualr of photo. It constantly says there is no paper when the tray is full.
Try changing the type of paper that you have under your printing preferences into hp premium photo paper instead of automatic.
Feb 14, 2011 | HP - HP Photosmart 8250 printer
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
My hp photosmart c6180 prints green photos on photo paper. it prints fine on regular paper. all my ink cartridges are hp and new. how can i fix this. i have tried several different types of photo paper as...
Check to make sure all of your contacts are clean. The part where the cartridge meets the printer. Also check to make sure you have it set in the printer properties for photo quality paper. If this still doesn't work, I would suggest trying a different brand of paper, it may be the problem with the paper manufacturer.
Oct 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
Out of paper message when there is paper
This video is for the C7280, but the instructions are supposed to be true for the 8250. Usually that message when you have paper means that the rollers in the printer are slick and not picking up paper. The video shows how to fix that.
Feb 10, 2009 | HP Photosmart 8250 InkJet Printer
My printer has suddenly started printing terrible quality photos
I discovered I had switched photo paper in the process. The new paper obviously isn't compatible with this printer. I went and purchased more of my regular paper and the pictures began printing well again.
Dec 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
Paper mismatch paper size to small choose a large size
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Dec 12, 2008 | HP Photosmart 8250 InkJet Printer
8250 hp printer
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program in which it was created.
  2. Click File .
  3. Click Print .
  4. Click Properties . The Printer Properties dialog box displays.
  5. Click the Paper/Quality tab.
  6. In the Size is drop-down menu, select the size of the paper loaded in the unit.
  7. In the Type is drop-down menu, select the type of paper loaded in the unit.
  8. Click OK .
hp website
Jan 29, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
183 people viewed this question
Ben Johnson
