Question about Sanyo Televison & Video
Need a power supply module for sanyo dp32647 - Sanyo Televison & Video
Sanyo model dp32647 fuse blowing
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 03, 2016 | Sanyo Televison & Video
What size screw do I need to secure stand to Sanyo 32" tv. Model NO DP32647
Usually its a M6 thread. length varies depending on the mount size.
Aug 15, 2015 | Sanyo Televison & Video
My Sanyo DP32647 has a really dark picture and i read somewhere online about adjusting the flyback problem is idk what a flyback is.
There is no fly-back transformer as you describes here, to no flat panel TVs. It has only back-light. If anything wrong happens to the backlight inverters, lack of brightness will be the result. If you wish to get more details about this, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 07, 2013 | Sanyo DP32647 32 in. LCD TV
EARPHONES For SANYO dp32647 tv
I have not researched this but nearly all tv's have a 3.5mm stereo socket for speakers or headphones
Feb 14, 2012 | Sanyo DP32647 32 in. LCD TV
Tv click it but no picture no sound power supply voltages are ok no out voltages on high voltage board
Try to remove the connector that supply the high voltage and observe if the unit will produce a sound. May be the inverter is faulty. Or try to check if there is a 24 volt dc supply to the inverter or the high voltage board.
Jul 14, 2011 | Sanyo DP32647 32 in. LCD TV
Sanyo dp3247 was working earlier today but when I turned it back on this evening I can hear it click on ..but No picture or sound. Help please?! I'm 86 yrs old and this is my source of entertainment. Is...
Tries tv unplug,replug it back like about an hour later.Most of the time tv will work again.Sometime is only a temp fix or the same problems will accur as the original problems.Than the tv have problems,with it power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 17, 2011 | Sanyo DP32647 32 in. LCD TV
Dp32647 no power
most likely need a fuse or power supply replacement
Robb
Sep 21, 2010 | Sanyo DP32648 32 in. LCD TV
Tv wont turn on
Usually the power supply is bad. Check the capacitors in the power supply. Some of the electrolytic caps will be puffed out, simply replace then and you will be back in business.
May 22, 2010 | Sanyo DP32647 32 in. LCD TV
No picture, no sound.
contact sanyo, sounds like your display panel has gone bad
Sep 08, 2009 | Sanyo DS31590 31" TV
Well my t.v. sanyo dp32647 will not turn on
Chek the fuses and if OK check the main power source board.
Aug 13, 2009 | Sanyo Televison & Video
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
