I have a Samsung 52" TV. Last night all by itself the TV just went off. A red button right underneath power button is lit, says timer. I cannot get the TV to go on with the remote or manually. Do you think by accident the timer button was set? Can you help me. Thanks.
  • tina6251 Sep 29, 2008
    No, the red button is not flashing. Did check power board.
    Hi, me again. Can you tell me what an IF and IC is. My husband is trying to solve the problem, but don't know if he will have any luck. Thanks.
    Sergeant:
    Champion:
  • 223 Answers
If this red button is lit is it flashing? If it is count the flashes and the gap between them as it is displaying an error code to you. Usually when a tv is stuck in standby or dead the first place to check would be the power supply board. Check all the diodes first as I have found that a faulty one can do many strange things. If you are not able to check this yourself please do not try find a competant technician. Hope this helps.
Posted on Sep 29, 2008
  • Paul Sep 29, 2008
    The only other things I can suggest is to check the I.F and line output board for a faulty I.C. Otherwise I am stumped!!! Sorry I could not be more help.
  • Paul Sep 29, 2008
    I.F stands for intermediate frequency and I.C stands for intergrated circuit. If your husband knows how to circuit test then look for the line output transformer on the circuit board, it should be black or grey in colour witha red lead sticking out of the top of it going to the tv screen. Check the components on that board for the correct voltage but DO NOT check the transformer or any large capacitors as some of these carry thousands of volts and only specialist equipment can be used. If he does not have the knowledge to circuit test but has an understanding of what each component should do then it will take a long while but check each component induvidually for the right parameters, and re-check the power supply board this way. An I.C is what some people call microchips and on the power supply there might be a couple with between 4 and 8 pins coming out of them, and at a guess they are voltage regulators which may have blown and taken out something else along with it. If he does not have a knowledge of what the components are and what they should do/read PLEASE call a competant technician as its dangerous voltages in a tv even when apparently dead. Hope this helps. Please post how you get on.
Samsung TV
Based on the information you described you may have a tuner
circuit problem or power intermitent faikure fron the power supply module.
Nov 02, 2012 | Samsung Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
I turned the Tv off last night and this morning it wont come on it shows to have power the little light on the power button is lit up red and when you try to turn it on it blinks but nothing happens. Model...
almost all of these have bad capacitors in them..
caps
http://www.fixya.com/support/r5000889-repairing_tv_just_clicks_over_over
Let me know if I can be of further assistance.
Jul 26, 2010 | Samsung LN32A330 32 in. LCD TV
I have a 52
No its require to change some parts
Jan 21, 2010 | Televison & Video
Green timer light wont go away
Hi.
The TV is in protect mode because there is an internal fault.
The TV must be tested and repaired at component level.
Call Mitsubishi at the number listed on the user manual.
You can also read my comment explaining more on protect mode here:Why my TV does not start up and remains in...
Dec 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung ps42a456p2 (42 inch plasma) won't power on, stays standby
i'm pretty sure the power supply board is dead. the most common problem with all samsungs.
Oct 30, 2009 | Televison & Video
My tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
Apr 07, 2009 | Samsung Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
