I love my hair straightener. It doubles for a clean modern straight look to sexy voluptuousness Kim Kardashian curls without going to the salon. If you do it right your hair will look professional and feel so soft.
1.
Clean and Wash Hair: I always like to have clean hair before I style it, it isn't necessary but it makes me feel more refreshed.
2.
Make sure your hair is dry. I prefer to air dry because it is the healthiest way to not damage your hair. But if you want to get more volume, using the blow dryer works well.
3. Before using any straightener make sure you get
heat protector gel or spray because this will help make sure your hair does not become damaged when styling.
4. I like to split my hair up into sections to get them out of the way by using hair ties or hair clips. Sectioning your hair also helps a lot of if you have specific styles you are going for.
5. Finally,
do not turn on the straightener too high because it's a sure way to damage your hair. Instead, consider low-med. If it's your first time, don't rush it because you will get burned. Give yourself an hour or more! Learning how to do it the first time can be frustrating and it doesn't always look great the first time. With some practice you can also create curls with a straightener as well.
Other tips: They have specific wet-dry straightener which can be used on wet hair but unless you have those, d
o not use the straightener with your wet hair because it'll give you split ends and damage your hair.
Here are some
more tips for straightening that might be useful for you.
