Question about Pioneer PRO-99 TV
Pioneer pro99 standby problem
I recieved this tv with a standby problem when powered on it starts to come on you can hear high voltage start then it will go from a green light  right to the red. I've hit all of the solder connections but same thing. Could you tell me where to start? Thanks
  • 1 more comment
  • davecorey1 Oct 22, 2008
    Same Story - out of the blue. The set will not turn on. It attempts to, and the red light briefly goes to green, but then back to red, and no start up.
  • Anonymous Feb 15, 2009
    I have the same problem,after I try to turn in on about 15 to 20 times it will come on. It seems that it comes on after it warms up. If iI accidently turn if off it comes back on right away. For now I have been leaving it on and just turning off the dish reciver , but I am afraid that the bulbs will burn out a lot faster if I do not turn it off when not watching it.
  • Anonymous Apr 19, 2009
    Same problem here
4 Suggested Answers
  • 68 Answers
SOURCE: Pioneer SD-P6091K problem with turning it on
Is this set several years old, and has it been good till now? There is one on the internet, 8 years old for sale with the same symptoms as your friends. There is an internet site `tv-forums.com. Presumably you have already looked with the back off. Make sure there is not a build up of dust, which will cause overheating. If it has a 150 watt UHP lamp, or similar,(expensive!) it may need replacing. The lamp must be cooled by a fan, so make sure this is srill working. There should be a thermal cutout which automatically resets.
Posted on Oct 25, 2006
  • 1153 Answers
SOURCE: Pioneer SD-62A5 has red standby light, won't turn on
Check C258 video assy.
Posted on Aug 16, 2007
MrBob84
  • 90 Answers
SOURCE: pioneer 710 hd power/not turning on 10/12/08
When the set goes into protection BANG like that, without any intermittencies, usually the convergence ICs have gone out and need replacing. I recommend using the STK 392-180s, which are the stronger upgrade to the 392-110s used originally. You'll need 2.
Mr Bob
www.imageperfection.com
510-278-4247
bob at imageperfection dot com
Posted on Nov 12, 2008
tducksoup1
  • 7 Answers
SOURCE: Pioneer SD-532HD5 Projection Screen TV won't turn back on.
the problem with pioneer projection tvs is that when they made the boards they never used enough solder for the circuits and you get cracks in the runs. thats why heat and cold will effect it. I had the same problem and I took out the board and resoldered every track I could and it works good now but my remote wont work if anyone has any info or prints to this tv please post on here
Posted on Sep 15, 2010
I have a pioneer Pro 200 and have had it for a dozen years. I have an HD in my office and the picture is so good and bright on the Pioneer I just cannot bring myself to get rid of it. The TV blinks off...
Im going to guess that if you try turning it on, sometimes you hear a "click" and nothing then the problem persists over and over until it finally turns on? If so, it's a problem with the power that "jumpstarts" the screen. Worn out capacitors on older models don't hold the necessary charge it takes to "start" the inverter that powers the screen. Once those start to go, it's usually bye bye for the tv. That is IF this is your problem. Let me know. Sometimes it makes hissing or cracking noises along with it. hope this helps!
Jun 11, 2012 | Pioneer PRO-200 60" Rear Projection...
Monitor no raster power has been ok
The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
Assuming there is no deflection and no High Voltage, you either have a low voltage power supply problem, bad start up circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
Check for bad fuses.
(If you have High Voltage as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
Use an ohmmeter to test the HOT for shorts. If it is bad, look for open fusable resistors or other fuses you did not catch.
Assuming it is good, measure the voltage on the collector-emitter of the HOT (this is safe if there is no deflection). You should see the B+ - probably between 100 and 150 V.
If there is no voltage, you have a low voltage power supply problem and/or you have not found all the bad/open parts.
If there is voltage and no deflection (no high pitched whine and no HIGH VOLTAGE), you probably have a start up problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for start up problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself).
If you hear the high pitched whine of the deflection and/or feel some static on the scree, confirm that the horizontal deflection and high voltage are working by adjusting the SCREEN control (probably on the flyback). If you can get a raster then your problem is probably in the video or chroma circuits, not the deflection or high voltage.
hope this helps......
Aug 06, 2010 | SAMTRON 77V 17" CRT Monitor
When i on the tv by remote the red standby light turns into green and i hear the tv sound but not picture and after a one or two second the green light turns into red. The tv goes into standby mode when i...
the high voltage or flyback transformer is not working.the sound runs off a separate fixed power supply.if you run your hand across the screen,is there static?that would mean the high voltage is ok but there is another circuit fault
Jul 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The standby botton blink 7 in my sony trinitron
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
May 07, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Weird issue with Pioneer VSX-D510 and "tone"-setup
clean the all push buttons by using isoprpylalchohol.(surgical spirit)and dry well .i think all the buttons are short by itself.the problem is still there please check the power supplu secondary side smoothing condencers related to system control power section.
nuwan
Oct 02, 2008 | Pioneer VSX-D510 Receiver
Rca 27410tyx1 will not shut off
Sounds like trouble in the standby/power up circuit. have you tried unplugging the TV for a half hour and seeing what happens? It might start up but I think this problem won't go away. If you heard a high pitched buzzing it sounds like a problem in the high voltage not letting the start up circuit work. threy are related. The start up circuit waits for the high voltage to stablize and then switches it on.
Sep 16, 2008 | RCA TruFlat 27F520T 27" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Oct 31, 2007 | Pioneer PureVision PDP-5040HD 50 in....
Sony Big Screen TV Not Powering On
This looks like a problem with the High Voltage or switching power supply section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, and check the voltage output of the switching power supply. What may have happened is a component may have shorted out causing an over-current condition with is triggering the shutdown circuit (These are the relays you are hearing). I would check the Horizontal Output transistor, and the components in that section of the TV.
In addition check the voltage test points on the HV / Horizontal and switching power supply board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I hope this helps,
Thank you,
Shuttle83
Aug 15, 2007 | Sony KP-46WT500 46" Rear Projection...
Oct 22, 2006 | Pioneer SD-P6091K TV
Televison & Video Logo
44 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
