My printer is hooked up and installed just fine.. however when i got to print, instead of the normal print box poping up its a fax box and will not allow me to print.. its as if my printers settings are set to fax as apposed to print
Not the printer...the FAX...won't go thru - comes back Phone Line Error
Posted on Sep 29, 2008
My MX700 printer tries to send faxes instead of printing page(s).
hi
change your default printer your mx700
1 - start menu
2 - printer and faxes
3 - right click on your printer
not on your fax icon
Jun 09, 2010 | Canon MX700 Office All-In-One InkJet...
DFX-9000 printing 2 Journals on 1 page instead of 1 per page
Have you tried to check the print settings?
Click on Start>Control Panel>Printers(Printers and faxes)> Right Click on the DFX-9000 printer icon>left click on properties>click the printing preferences button located below the properties box. In this window you should see the setting of the printer itself.
Sep 05, 2009 | Epson DFX-9000 Dot Matrix Printer
We try to print something and the fax pops up wanting a fax address we have never used the fax I have a Canon MP530
the default is set to fax instead of printer. go to control panel. printers and faxes, then you will see "fax" and "printer", i think you will see a check on fac meaning it is the default printer.
Right click on printer, choose default and your problem should be solved.
if u have problems finding the above then you can find something to print, choose print from the file tab, a box will open and it has a drop down menu with the fax and the printer, click on the printer!
hope this helps!
Aug 13, 2009 | Canon PIXMA® MP530 All-In-One Printer
Installing printer to mac.
On Mac, You have no silly popups when you print something, instead you'll just see the printer icon in the dock, or bouncing if it needs your attention, if you installed the drivers, and you can print, and all other functions work, that's all that matters. Search Apple or your manufactures website if you want additional scanning / faxing software if needed. Also, info about your printer is found in System Preferences --> Printers and Faxes (or similar name) and double click your printer, other wise, use the buttons below for other options.
Apr 28, 2009 | Computers & Internet
My HP 2610 defalt has changed to fax instead of print mode
follow this trouble shooting steps your issue should resolve.
On Computer:
Click on Start >> Control Panel >> Printer and Faxes >>
check which Icon is enabled if Fax is Enabled Just Disable it By right clicking on it and Disable.
Now Right Click on Printer Icon then select " Use Printer Online"
then set it as Default Printer.
Now try to print your issue should resolve..
I hope it helps ...raj 9866486995
Raj....
Feb 17, 2009 | HP Photosmart 2610 All-In-One InkJet...
Canon PIXMA MX310 All-In-One - faxes storing instead of printing
When the machine is in one of the following situations, the fax is automatically stored in memory.
- If ink is low or has run out while receiving a fax
- If the paper size/type setting is incorrect
- If the paper has run out while receiving a fax
- If the Output Tray is closed
- If OFF is selected for AUTO PRINT RX
- If you pressed the Stop/Reset button to cancel printing of a fax
The most likely problem is that the ink is low.
You can change the settings to still print if the ink is low by pushing the fax button and then the menu button.
Scroll over until you get to RX settings (I think it is the 6th option) and push OK.
Choose the option to Auto Print RX, and press OK.
Make sure that On is selected and even if it already is the chosen option, press OK.
When the option appears to print with no ink, select yes. This will allow the fax to print even when the ink is low.
Sep 04, 2008 | Canon PIXMA MX310 All-In-One Printer
My comp. says my printer i s hook up put will not print the fax copy od scan works fine
check your print queue is empty, if not clear it (double click onprinter, select cancel all docs on printer menu. if that doesn't work, uninstall the software and drivers completely, unplug printer, restart computer then download and install latest drivers. plug the printer in when the software tells you to
Aug 30, 2008 | Lexmark Office Equipment & Supplies
Can't receive fax - fax rings 2ce then just stops / says phone off hook
Hi Iryan,
Instead of switch box, a more dependable option is to get a distinctive ring. Your local phone company offers this option. What's neat about is you get a seperate fax number. Its like having a dedicated fax line without adding extra lines to your service. I think the monthly fee is around 3 dollars a month for this feature, but, believe me its well worth it.
anaanymous
Jul 15, 2008 | HP Officejet 4110 All-In-One InkJet...
Canon Pixma MP530 multifunction printer comes up as a fax
This is absolutely the right solution. I used this for my Canon MP780 printer under Vista, as well. I want to include all of the keywords here. It is important to note that the DPR-1260 shipped with Firmware Version 1.12 cannot be seen by Visa until it is upgraded with the Version 1.21 firmware, but after downgrading back to the Version 1.12 firmware, the DPR-1260 is still visible and it now recognizes my Canon MP780 multifunction printer as a printer and not as a fax machine. I plan to post this same solution to other sites, so that hopefully others can get their DPRs working again. Whew!
Sep 10, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
471 people viewed this question
k24674
jasbo
jasbo
