Question about HP DeskJet 842c InkJet Printer
Ink system failure Oxc19a0031 I have an HP842C. The ink cartridges appear to be full, and in fact I have changed them for new ones, but I barely get a print, It is sometimes enough to make out (barely) other times it is just a blank piece of paper. Any suggestions? ( i can't afford to buy a new one)
  • 1 more comment
  • Anonymous Oct 08, 2008
    Same problem.
  • Anonymous Dec 07, 2008
    Same problem here exactly as described by tbacks.
  • Anonymous Dec 23, 2008
    same problem - two brand new cartridges and get blank page.
Clean the cartridges.
Go to Printers/Faxes from your START Menu
Select the printer
Select Set Printer Properties
Select the Services Tab
Clean them - I had to do it 5 times and take out the black cartridge and shake it really good until ink started coming out and clean it again. I primed 3 times.
Worked for me.
Posted on Dec 23, 2008
I have error code 0xc05d1281 what does this mean?
This error means "Ink System Failure"
And it means that something went wrong in the ink manager internal printer software.
Try removing all the ink cartridges and then power off and on again the printer
If it asks for inserting the cartridges insert them one by one and see if the error appears, in that case the thing that provoke that error is that specific ink cartridge.
So change the specified ink cartridge.
If you didn't solve with this procedure maybe the printhead failed to do a specified operation, or anyway the printer have a specific error on the mainboard and need assistance
Let me know ;)
ADCSFXworks Printing Center
Mar 10, 2015 | Office Equipment & Supplies
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
My Printer prints a Colored Ink. But I type as a black Font Color.Then Black Ink Has full?? pls help me
Hi Carl Montero,
Your issue may be attributed to two possible points of failure. 1.) The Nozzle is clogged, 2.) the ink is already dry inside. You can try to clean the nozzle by doing the following steps. If it does not work, try to replace the cartridge with a new one.
FINE Cartridge Cleaning
1 Press [Menu] repeatedly until appears. 2 Use [ ] or [ ] to select . 3 Press [OK]. 1 Press [Maintenance] repeatedly until appears. 2 Press [Black] or [Color].
FINE Cartridge Deep Cleaning
Note If deep FINE Cartridge cleaning does not improve the print quality, contact a Canon service representative.
Jul 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I have a HP Officejet Pro L7680 and have enjoyed a year of problem free use. Now the printer says "Ink Cartridge Problem" :The following ink cartridge appears to be missing or damaged" ...
Hi
You need to replace the Yellow cartridge
with a new one couse the old one either
has expire or has problem with the chip
on cartridge
ps vote us to keep us alive
Nov 06, 2010 | HP Officejet Pro L7680 All-In-One InkJet...
0xc18a0401 ink system failure error on hp C6180 printer
Check out this link.
http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp/
Apr 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have the ink system failure error and error Oxct18a0206 I was going to try and fix it and it somewhere it said that it could be because the ink cartridges are low. How do you see what level they are at...
Yes, The error is caused by air in the ink feed tubes which happens when the ink in the cartridges runs out or you use an improperly filled cartridge. We have a step by step repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
There is not any easy way to determine the level of ink in the cartridges but you will need to use full cartridges when you do the air purge procedure needed to clear the error.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink system has failed error Oxc 19a 0031
Are you experiencing the ink system failure on your printer? The error is caused by air getting in the ink tubes feeding the system. This is normally cause by refilled cartridges but can be caused by any cartridge that goes very low on ink and then tries to reload ink. This reset procedure does have to be performed with a full cartridge installed. The following reset procedure will correct the issue by purging the ink tubes and flushing any air trapped in them.
Please perform the following steps in order:
1. Press and hold the “*” key.
2. Press the “#” key and release both keys.
3. Display should say “Enter Special Key Combo”
4. Press and release in sequence the “1”, “2” and “3” buttons.
5. Screen should say "support" R0631M"
6. Press and release the right arrow button until the display says “System Configuration Menu”.
7. Press and release the “OK” button.
8. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
9. Press and release the “OK” button.
10. Display should say “Hardware failure status: Clear. Press OK to clear”.
11. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
12. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
13. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
14. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
15. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
16. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
You should be back up and running.
I hope this helps, If so pleae rate our solution
Nov 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure on a HP Photosmart C6280 All-in One
This is likely a cartridge problem except if the carriage is not moving at all. If you still have some of the used cartridges you can used them to trouble shoot by elimination ok. Or contact a nearby technician who has the cartriges to use them for trouble shooting. I strongly believe the one of the print carts is the culprit. Good luck
Jun 02, 2009 | HP Photosmart C6280 Printer
Ink system failure
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Sep 14, 2008 | HP Photosmart C6100 All-In-One Printer
HP DeskJet 842c InkJet Printer Logo
247 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
