Question about Maytag Kitchen Ranges
Maytag f1 and f12 error code what problem are these codes indicating.
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Can you give us the Model number of your range and the year or how old it is!
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    Maytag Bravos error code f1
    F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
    Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
    Clock displays f1 oven will not work
    The F1 error code on this model of Maytag range indicates a problem with the electronic control board for the oven or with the oven temperature sensor probe. A technician will need to diagnose and repair this type of failure.
    The technician will normally check the resistance of the temperature probe. If the temperature probe resistance is normal, it is likely that the electronic oven control will need to be replaced.
    Apr 17, 2011 | Maytag Kitchen Ranges
    The f1 code on the Maytag Bravos top loading washer keeps going off and stopping the machine
    Please contact Maytag to inquire about the code F1. They should check the system and that that code is a courtesy repair and should be scheduled for a someone to come out to fix it. FREE
    It is possible that the F1 code was caused by your laundry habits (detergent), but I think that is unlikely. Too many of these machines have problems with the F1 error code. There is a known problem with the Oasis / Cabrio / Bravos machines.
    Aug 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
    F1-1
    Hi
    Thanks for using FixYa. Error code F1-1 in your Maytag Gemini Indicates runaway cook in upper oven and to resolve this issue you’ll have to check the oven temperature sensor & replace if it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jul 20, 2010 | Maytag MER6772 Gemini Electric Kitchen...
    F1...
    hello,
    what this code mean is an error code indicating that there is a lost of connection on the door or on the control panel meaning that the door is not properly close
    thank you and thanks for using fixya.
    Jul 09, 2010 | Maytag Ovens
    F1 Error Code on MayTag range
    migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
    Jun 05, 2007 | Maytag MER5875QA Electric Kitchen Range
    Kitchen Ranges Logo
    345 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    gbob59
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
